Posted by Roy M on 25/04/2015 15:07:40:
Ref; Reaming. It may be that the coolant mix is not usually used at max strength, or closely monitored,but you have probably noticed that you get a different finish when using cutting oil and it is most likely the same phenomena. I know that the science of cutting fluids is complicated and my observations are only gained from experience and are not at all scientific! I would reiterate that the difference is small, but it is a trick worth knowing. Roy M
Thanks for the thoughts, Roy
My own [wild] guess is that the Rocol lubricant enables the reamer to cut a near-perfectly circular hole; but the water based fluid allows some chatter [for want of a better term] and produces a very slightly lobate hole.
… any sense in that ?
Trick noted for future reference, anyway !!
