Thanks Graham,
I do use my reamers faster than I used to, but it looks like I should step up another gear!
I will bear in mind what you say about periodically withdrawing hand reamers – i did manage to chip a couple of the cutting edges on one once, and still have no idea what caused it. It still works, as the chips were near the tip of the lead, and it didn't affect it where it cuts full size. I have considered cutting off the end and regrinding it as a machine reamer – that seems a lot easier than grinding off an awful lot of metal to restore the lead, also I could do the former without making a flute grinding attachment for my grinder.
I have noticed that all my reamers give a relatively easy fit on silver steel of the same nominal size. For this reason I tend to use them when the finish in a hole is the most important consideration.
It's amazing how much there is to learn about apparently simple tools.
