Ahhh, with the pulleys… user error again i guess,
yes i looked on amadeals site for replacement belts, saw the one listed as XL, and presumed that's what i have, my belt is marked '1.5M-70-9.5' which i believe means it's 9.5mm wide, 70mm long,
I've just rendered a 31 tooth T5 style pulley slice in openScad, and it's produced a pulley that is 48.44mm diameter. It can't do an 'X' pulley,
But i'll look at other pulley makers as mentioned, i'm fine with things being public, i'Ve been printing lots of things others have made and shared on thingiverse and that.
I quickly found out i needed a bigger lathe shortly after buying this one, but that was because my first project was to turn some discs or alli into control levers for a train simulator controller i was making for myself,
i ended up using the myford lathe at my then local hackspace to reduce the discs down to a size i could fit in my lathe at home.
But after that i mostly used delrin, acatel, nylon and aluminium in this little lathe, the odd bit of steel was small so machined ok,
But i'm finding myself wanting to machine more steel now, another project is to turn a piece of EN3B bar for my bus simulator build,
Not knowing much about steel i just went on ebay and bought the first bit of steel the size i needed for a cheap price (if £8.25 is good for a piece 40mm by 200mm)
But i already know that when it comes to parting that EN3 steel off i will be using the cold cut saw which is on the delivery van to my place right now.
One day i will buy a bigger lathe, one of the warck's i think, it'll have powered cross feed and a quick change gearbox as a minimum,
But i want a small (as in about WM14 size) milling machine too, and really want to get one of them before i upgrade the lathe,
