Posted by Peter Bell on 01/08/2018 13:45:29:
My application would be around 3/8", is this too small to be practical?
Peter
I don't see any reason why an interrupted thread wouldn't be practical at 3/8" diameter. They're easy enough to make in simple form, but remember that removing large slices of thread weakens the joint. Used on artillery because the breach swings on a hinge. The interrupted part allows more clearance, allowing a more compact construction. For obvious reasons considerable care is taken in design and manufacture to make the breach strong enough; an artillery interrupted screw isn't easy to make because the male and female are made to close tolerances out of tough steel.
Apart from artillery, I don't recall seeing an interrupted screw on an ordinary object. The more usual alternative is either a bayonet fitting or a multi-start thread. A 2 start thread unscrew twice as fast as a single etc.
