Quick Machinists Jacks
Home Forums Workshop Tools and Tooling Quick Machinists Jacks
  • #19533
    Vic
      @vic
      Vic
        @vic
        I have on several occasions needed a Machinists Jack or two but didn’t have one. I resorted to packing up the work with whatever came to hand and made a mental note to add making a couple of jacks on the “to do later” list.
        For one reason or another they’ve been pushed back – for a couple of years! laugh
        Then I came across this idea on a website and went on a hunt in the workshop to see what I had. I knew I had the long connecting nuts in M12 Stainless somewhere and I also found some M12 cap head socket screws. I just got a couple of bolts and some half nuts on eBay. It was then just a case of skimming the ends of the long nuts and the tops of the bolts which only took a few minutes.
        Obviously not as fancy as some jacks out there but these will do me just fine.
        #437691
        old mart
          @oldmart
          Its nice to have a small supply of these jacks, they don't get much use, but when they are required, they are worth their weight in gold. We have a selection from about 5/8" starting height to 4", I have only needed them once. The long threaded couplings included in the tee nut clamping sets have potential for dual applications.
          #437728
          Vic
            @vic
            Forgot to add the site I saw them:
            If required I’ll drill my two stainless bolts for additional fittings as suggested.
            #437746
            old mart
              @oldmart
              I looked at the link, and one think caught my attention, the use of screwjacks on a lathe faceplate. You would have to be very careful in that application, to allow for centripetal forces, of risk getting a nasty surprise.
              #437759
              Clive Foster
                @clivefoster55965
                By the very nature of things machinists jacks made from joining nuts have a rather small footprint. Makes them less stable than the conventional kind but also means you can squeeze them in where a bigger one won't go.
                Several years ago I ended up with a handful of joining nuts left over from a job and considered making some jacks like that. I planned to make larger feet to screw in the bottom if needed to make them more stable and / or bridge the mill table slots. Was going to make my feet round but, on reflection, suspect rectangular ones might be more successful. In reality I'd probably have made feet on demand by poking a countersunk head screw through lump of "whatever" roughly shaped to fit the space and eventually ended up with a collection of shapes and thicknesses that worked for me.
                In the event I lucked into several properly made jacks and spacers for "£ very little" before I got round to making mine.
                You will almost certainly need some "pointy cap" ended screws to help support less than flat or less than smooth items. Best to make some whilst you are at it. Odds are when you need some you won't have any suitable studding or set-screws to hand. I often cheat when that sort of "Will need it. But when?" thing arises and sequester some material stock. Been 20 years before it got used on occasion!
                If using them on a lathe faceplate obviously bolt them through from the back so they stay put. I'm not brave enough to use a conventional machinists jack on a faceplate!
                If you have 1-2-3 blocks consider making adapter studs so the jacks screw into the blocks. Sometimes you need a tall support.
                Edited By Clive Foster on 17/11/2019 21:34:24
                Edited By Clive Foster on 17/11/2019 21:35:45
                #437763
                old mart
                  @oldmart
                  That's a good point, I had forgotten about the threads in 1-2-3 blocks.
                  #437768
                  IanT
                    @iant
                    Posted by Clive Foster on 17/11/2019 21:33:58:
                    That's an excellent idea Clive – I'll add it to my TUIT list and make some for my 1-2-3 blocks…thank you.
                    IanT
                    #437782
                    Chris Evans 6
                      @chrisevans6
                      Over the years I have made many jacks, some fancy tapered turned affairs others just a rectangular block. Before then I pressed a tee nut into service with a suitable bolt.
                      #437793
                      Circlip
                        @circlip
                        Can also be used as adjustable "Slip gauges" (use a mic to set the height) for a sine bar, unless you're working for NASA.
                        Regards Ian.
                        #437797
                        Vic
                          @vic
                          Sadly I don’t have a faceplate for my lathe so not an issue for me. Hopefully I’m out in the shed today to make a V block with a spigot to fit the hole I’ll be drilling in the hex bolts. Good idea about the adapter for use on 1-2-3 blocks but they have Imperial threads. Luckily I have some Stevenson's Metric Blocks tapped M8 so I can use those. I need to make some M12 – M8 adapters now … And there I was thinking it was a quick and easy solution! laugh
                          Edit: Yes thanks for the idea Clive. wink
                          Edited By Vic on 18/11/2019 10:37:28
                          #437811
                          Chris Evans 6
                            @chrisevans6
                            M12/M8 adaptors available commercially for pennies. Not worth the effort to set up.
                            #437851
                            Vic
                              @vic
                              Posted by Chris Evans 6 on 18/11/2019 12:28:38:
                              I might normally agree with you but I’ve already got 5 metres of 12mm threaded rod sitting in the shed. It will only take me a few minutes to put an M8 thread on a couple of bits. I only want two.
                              #437853
                              not done it yet
                                @notdoneityet
                                1-2-3 blocks will usually only need a set screw and a locking nut, for adjustable height, + something to secure the block to the faceplate.
