Quick change tool post for myford mtype 31/2″ long bed
Home › Forums › Beginners questions › Quick change tool post for myford mtype 31/2″ long bed
  • #409110
    Grant Allen 1
      @grantallen1
      Has anyone had any problems fitting a modern tool post to the slide carriage, any issues you've come across and if alls working fine which brand and type did you use?
      I would just like to say all the help I've received on has been 1st class and has helped me and hopefully other people starting out in this field. teeth 2
      #9664
      Grant Allen 1
        @grantallen1
        #409115
        David George 1
          @davidgeorge1
          Hi I have fitted a Dickens type bought from Myford. Here is picture and sketch of my mod.
          David
          #409116
          Grant Allen 1
            @grantallen1
            Brilliant cheers David. Did you have and issues, obviously I dont have a lathe to do out on till this is done. Its abit like the lead screw half nut cant make one the lathe and cant make one with out a lathe.
            #409118
            ianj
              @ians
              I've used for several years a Bison (Tool mex) Type 4414 48 x 37 some times named T001 or S001 with a suffix of M or not.. They are a direct fit on the top slide of ML7's and Super 7's.They are expensive but top quality.
              Edited By ian j on 13/05/2019 18:24:58
              Edited By ian j on 13/05/2019 18:26:39
