Hi all
“Put a bit of (true) bar of sensible size into a 4 jaw, and clock up true” ? in the post above.
An interesting proposition. If the point to be measured on the bar is adjusted to be to be spot on the axis of the lathe spindle the indicator will “clock” perfectly; all good.
But what if at the same time the bar is actually off axis as it passes through the chuck jaws? the indicator will read a regular rise and fall as it travels the path of the ellipse generated, however the rise and fall will be very small, and maybe not noticed.
The small error however will be multiplied by the length of the square. it may well be significant.
A possible solution particularly for a longer cylindrical square is to finish face the ends using the fixed steady well oiled and fitted carefully with no play at one end. and only gripped by the last few mm in the chuck jaws at the other end (perfectly clocked true at that point near the jaws)
As only a small finishing cut is required a light grip will be sufficient.
This method effectively assures that the axis of rotation (of the bar) is correct at 90 degrees to the cut. while facing the ends.
The fixed steady is another source of possible errors, if off axis it stresses the chuck jaws, if it is not correctly aligned with the chuck, so this setup should be done carefully. However if the fixed steady is slightly off axis the most likely outcome is the bar will slightly flex the chuck jaws in and out (it is constrained in the fixed steady at 3 points). however the work will still rotate on its own axis.
A good analogy of this setup is the drive shaft of the car. The shaft rotates on its own axis while it can move up and down.
The setup of the fixed steady should ideally be centered on the lathe axis of rotation within .001 inches or less that way the errors generated by the less than perfect connection at the chuck will be minimised.
Cheers
Edited By John McNamara on 06/01/2012 00:00:17
