As a whole the East African area is so varied that talking about climate in one place is not worth it. The humidity at the coast is high, maybe 100% for part of the year but just hot for another part. Go inland and in some areas desert conditions exist with areas laid waste by Elephants and denuded of trees and only dried stumps remain. Some Elephant herds travel upwards of 20/50 miles a day to feed and tramp back at night to water!
Areas above 5/6000 feet altitude are different as this is the area of rain forest usually around the Mt. Kenya and Kilimanjaro foothills. Here valleys have rushing streams full of Trout and Char whereas lower down the dams and lakes are full of Tilapia and Black bass.
Added to this is the period of the long rains and the short rains and it is this that the migrating herds of Wildebeeste and impala and Zebra follow in a cycle, each period is likely to cause flooding of immense proportion. Roads washed away including bridges etc.
Farms drill boreholes to water cattle and wildlife but a lot of boreholes are no good as the water has flouride in it which dairy cattlle pass on through their milk. Nairobi is watered from a dam, the sasumau dam which again is full of Trout, both brown and Rainbow plus Char. There are a few wind pumps that are in use and the output is quite low, pump bore of say 50 mm and a stroke of 75 mm.and of course dendant on wind.
Weather wise it can range fronm towering Thunderstorms to long hot dry periods. Travelling down from 6000 ft to say 2000 ft brings you into the humid zone. Different foliage like Coconuts and other broadleaf trees. Wildlife tends to match the terrain from semi desert to rain forest.
Add to all this is the increase in population over the last say 20 years and the enormous increase in demand for water, new settlements given to loyal citizens for supporting Kenyatta were give plots of land about 100 mters square, they stripped off the foliage and dumped it in the ditches and by doing so change the drainage and in doing so caused flooding. Then to support crops they used water from rivers and the Tana which at one time was a rushing river is now just a dried out riverbed. Subject then to catastrophic flooding.
