I recently acquired a nearly new Proxxon milling machine from the estate of a deceased friend. When it is turned on, there is a lot of noise from the motor brushes/comutator. I mean A LOT. Is this common? How have others improved this; assuming that they had a similar problem. I was considering undercutting the insulation between the copper segments. We used to do this on some motor driven generators where I worked.
Regards Maurice
