Primer for metal
Primer for metal
Home › Forums › Beginners questions › Primer for metal
  • #63076
    Dougie Swan
      @dougieswan43463
      Hi,
      Can anyone reccomend a good primer for bare metal, ferrous and non.
      I have tried cellulose primer under enamel but cant get very good adhesion
      Any help will be greatly appreciated
      Dougie
      Edited By Dougie Swan on 24/01/2011 20:53:53
      #5374
      Dougie Swan
        @dougieswan43463
        #63078
          For non ferrous (and ferrous if you like) then etch primer is the way to go. I use the one Phoenix do – BQ23 if spraying use their thinners
          J
          #63079
          mike os
            @mikeos54812
            depends on what you are painting and how you are applying it, but I would usually go for etch or epoxy as a primer.
            #63082
            David Clark 13
              @davidclark13
              Hi There
              A couple of things, Self etching primer will etch your aibrush or paint spray.
              Use a cheap one if spraying.
              Phoenix do at least two etch primers, a single part in Grey and a two part in black.
              The shelf life is short but I read that you can rejuvenate it by adding thinners.
              regards david
              #63095
                David, they do a single part etch that only starts etching when dry so as long as you clean the airbrush out straight away it will be OK
