Edit..crossed with above post
I hope I didn’t seem grumpy.
In the absence of your actual “requirements”..it is un surprising that my or anyone elses suggestions are off target..
Lets say you want a bar with concentric and parallel “journals” on either end. Of defined diameter.
Between those journals you need flats for convenience. .
You have a mill of such and such a scope.
You have a lathe of such and such center height and between centers
Me I might start with square
Mark centers.drill centers ..mount between centers on mill…mill flats flat at “required” locations..mount on lathe between centers and check flats..when happy with flats..
Turn boss as required..
You now have bosses concentic With each other and referenced to the flats. .
This still leaves the issue of blend
But if you do the above with round stock and turn all over you get the flats as required and a concentric part…
Edited By jason udall on 08/03/2014 09:30:10
