The world of model and hobby engineering
Forums
Help
Register
Log in
Home › Forums › Beginners questions › portass ‘s’ lathe thread
Hi, I wondered if anyone knows the size and type of thread on the spindle end to take the lathe chuck backplate.The one on at the moment has been homemade and does not run very true.Any help greatly appreciated Thanks.
Can you not measure it? Usually a thread has a diameter and number of threads per inch [TPI]
But possibly you would need to remove the existing pulley[?} backplate{?} to do this.
They used "S type" to describe several versions so you will likely have to do as said and measure the thread, see here
Hi thanks for the replies,have measured and found the diameter to be 3/4",and 16tpi.
Started by: Andrew Tinsley in: Model Engineer.
duncan webster 1
Started by: Jens Eirik Skogstad 1 in: Electronics in the Workshop
Started by: Steve Huckins in: Beginners questions
Steve Huckins
Started by: markcs in: Locomotives
noel shelley
Started by: Dalboy in: Materials
Dalboy
Started by: JasonB in: The Tea Room
Speedy Builder5
Started by: Michael Gilligan in: The Tea Room
peak4
Started by: Graham Meek in: Manual machine tools
mgnbuk
Started by: odessit in: Introduce Yourself – New members start here!
Dave Halford
Started by: davelong22 in: Beginners questions
davelong22
Started by: Peter Cook 6 in: Manual machine tools
Peter Cook 6
Started by: Michael Callaghan in: Beginners questions
Started by: Dave Halford in: Workshop Tools and Tooling
bernard towers
Started by: Rainbows in: Manual machine tools
Oily Rag
Started by: teamricky in: Stationary engines
teamricky
Started by: jaCK Hobson in: The Tea Room
Started by: Nigel Graham 2 in: CAD – Technical drawing & design
Nigel Graham 2
Started by: Andrew Tinsley in: General Questions
JohnF
Started by: bjcolyer in: Introduce Yourself – New members start here!
Started by: ian Holdsworth in: Beginners questions
Ches Green UK
Started by: Michael Gilligan in: Website Questions, Comments, and Suggestions
Mark Rand
Started by: Graham Stoppani in: CAD – Technical drawing & design
Fulmen
Started by: Andy Stopford in: The Tea Room
Macolm
Started by: Martin Johnson 1 in: Workshop Tools and Tooling
DC31k
Started by: drnewcomb in: Manual machine tools
ega
