Polishing Castings
Polishing Castings
Home Forums General Questions Polishing Castings
  • #26271
    Matt Stevens 1
      @mattstevens1
      Matt Stevens 1
        @mattstevens1
        Now that I have started to make bigger parts – i.e. a 7" flywheel, I am finding that using various grit papers to polish becomes a magnitude harder! I would like to get the flywheel to a mirror finish but I am finding using 600-grit is really just polishing the edges and not particularly removing the machine marks.
        Does anyone have any hints and tips? For example – what about using a buffing wheel and polish sticks using a grinder?
        #378395
          If you still have machine marks when using 600 grit you have not worked through the grits correctly.
          First obviously aim for the best finish you can get off teh tool then say start with 120g to remove all tool marks, then 180g to get rid of the marks from the 120 and you should be able to get a bright finish with 320g. If you want to go further then do so but make sure one grit has removed the previous grits marks or you will just be polishing scratches.
          personally I stop at 150g which gives a nice sheen rather than an unscale mirror finish
          Edited By JasonB on 30/10/2018 18:32:54
          #378399
          Matt Stevens 1
            @mattstevens1
            Ok….maybe you are right and I need to start with a more coarse grit. ….. I just wondered if there was another technique that was perhaps more effective (hence the comment about a polishing wheel on a dremel or bench grinder)
            #378400
            Zan
              @zan
              You need to work down the grades of abrasive, when all the lines are from the current one, it’s time to go onto the next. With f lat material this is easy as the idea is to use each grade at right angles to the previous one, making it very clear when the marks from the previous one have been fully erased. Do not buff! This will seriously round the corners and remove detail, unless you are using it for a final light polish. It’s difficult to keep it even  a Drexel would be even worse, too small and easy to form depressions, tiny, but so obvious when a high finis is wantedAlways use abrasive on some form of backing, hands are rounded, and just holding it will round the work. Sticks, files etc can be used.
              If your flywheel is cast iron, a mirror finish is difficult due to the natural micro holes (or pits) found where the free graphite in the iron was previously located. Good luck  mirror polished work in my opinion always looks so poor, it’s completly non standard some people seem to polish everything, although it does have its place with brasswork, but not machined components
              Edited By Zan on 30/10/2018 18:29:14
              Edited By Zan on 30/10/2018 18:33:35
              #378406
              Richard S2
                @richards2
                Whatever the casting base metal is, the process is more or less the same. Depends whether it is a machined surface, or the rough casting that is to be polished. Machined/ part finished surface is finished as mentioned above.
                Finish is a personal choice and can be for practical reasons. The finish on my TE Flywheel (cast iron) here-
                …….is achieved with the process described above by Jason B (35 years ago). The high finish is to resist any corrosion due to my very slow progress on the project and proof that a good finish is more resistant.
                There are some before and after examples in my album of rough to polished castings in bronze as well.
                Patience is also a requisite, so keep at it and good luck.
                Edited By Richard S2 on 30/10/2018 19:16:34
                #378412
                Mark Elen 1
                  @markelen1
                  I made up a couple of sticks as described here: **LINK**
                  Really easy to make up and they last for ages.
                  Cheers
                  Mark
                  #378414
                  Dalboy
                    @dalboy
                    Like any hobby that uses a sandpaper/emery paper to smooth a surface the important thing is to start with a grit that will remove (in your case machine marks), then when you have removed those go to the next grit of paper in the range. Do not skip a grit and remove the marks of the previous grit each time this will make it easier to get the required finish that is needed
                    #378481
                    Philip Rowe
                      @philiprowe13116
                      Posted by Mark Elen 1 on 30/10/2018 19:55:06:
                      Cheers
                      Mark
                      I'm ashamed to admit I've always bought mine (being lazy) but having watched that video I will definitely make my own from now on. One thing though, do the multi layers formed by wrapping the emery tend to make a cushioned surface as opposed to a single layer glued to the wood? Clearly the ability to tear off worn parts must be a great advantage.
                      Phil
                      #378520
                      Nigel McBurney 1
                        @nigelmcburney1
                        The original engine flywheel would not have been polished, just machined ,most small engines were painted on the rim, Collectors and model makers do like to see cleaned up flywheel rims though scaling down to a 1/4 a reasonable slightly grained finish is all that is required,polishing to a chrome like finish is wrong.I was trained to use use emery paper wrapped around a 6 inch file which had been ground flat and all the teeth removed, known in our works as a "papering file" as we never used emery cloth only emery paper which stays flat,emery cloth is stiffer and so does not lay flat on the file and tends to remove material from the centre and does not keep the work flat.Lubricate the emery with 3 in 1 oil or diluted hydraulic oil to keep it cutting and do not go too fast, be careful with the oil to much oil splashed all over the casting, as it can affect paint adhesion, when finishing optical benches and the beds of travelling microscopes, after painting and before assembly any marks on the grained machined cast iron surfaces would be cleaned up with a few strokes of dry emery wrapped around a very flat wooden block.I once heard that clockmakers polish everything,isntrument makers straight grain every thing.
