Posted by Michael Gilligan on 05/07/2016 08:23:02:
Using the same 'inputs', I would have concluded that a 'bond' which is fully distributed over the joint area would be more resistant to the kick, and would therefore have used either a fully silver soldered joint, or [more likely] Loctite 638.
Micheal see earlier about knowing if the joint is fully penitrated and keeping the bearing surfaces free of solder. I have also made cranks that are fully soldered and its a pain to clean the solder off particularly the pin if you want to avoid removing steel as well as solder, little point in using precision ground material and then running a file over it.
