Pickling
Pickling
Home › Forums › Workshop Techniques › Pickling
  • #701646
    David Deaville
      @daviddeaville66164
      What do you guys use\recommend for pickling Brass and Copper after Silver Soldering please.
      I haven’t tried to do it at all yet so any advice would be good.
      Thanks
      Dave.
      #701651
      Nick Clarke 3
        @nickclarke3
        Traditionally sulphuric acid but this is listed as an Explosives precursor nowadays so the slower citric acid is substituted
        #701661
        noel shelley
          @noelshelley55608
          As Above ! where abouts in the UK are you, I may be able to help you. Noel.
          #701672
          Fulmen
            @fulmen
            Sodium bisulphate should work, it’s sold as pH-down for swimming pools.
            #701695
            David Deaville
              @daviddeaville66164
              Hi Noel,
              I’m in Malvern, Worcestershire.
              #701699
              David George 1
                @davidgeorge1
                Hi I use wicks brick and patio cleaner £19 for 5 litres and works well. you can reuse it many times. It is an acid so wear protective equipment and wash of in plenty of water. hydrochloric acid 5 – 10 % concentration.
                Sika Brick and Patio Acid Based Cleaner – 5L
                David
                #701722
                bernard towers
                  @bernardtowers37738
                  Citric acid super safe if you have kids/grandkids
                  #701726
                  JA
                    @ja
                    Citric Acid + a biocide. CuP Alloys Cleaning Salts does the job, right grand.
                    You really don’t want to mess around with Sulphuric Acid etc, just use the correct stuff.
                    JA
                    #701731
                      Another vote for brick cleaner does in 20mins what citric does in 20hours.
                      Works on steel and will also remove mill scale but don’t leave for too long. 40mins is enough and that will also remove HT5 and Tenacity No5 flux
                      #701742
                      Nicholas Farr
                        @nicholasfarr14254
                        Hi, yes brick/patio cleaner does work well, but you need one that contains hydrochloric acid, this is the one that I get https://www.toolstation.com/bostik-cementone-brick-patio-cleaner/p29118
                        Regards Nick.
                        #701746
                        Martin Kyte
                          @martinkyte99762
                          I use Dry Acid Pickling Salts which I used to get from GLR. Citric will work just as well. Norman Billingham did a very informative article in ME a while back explaining why weak acids are better to use in a home workshop as they don’t generate corrosive gas which then gives you a rust problem and work just as well.
                          In addition as dry salts can be sent through the post and are not on the dangerous chemicals list are readily obtainable.
                          The primary reason for using Sulphuric Acid in the past was that it was cheap and easy to obtain rather than being best for the job.
                          Regards Martin
                          #701756
                          David Deaville
                            @daviddeaville66164
                            Thanks for all the advice, I think I will give Citric Salts a go and if that’s too slow I will try the brick cleaning option.
                            Dave.
                            #701771
                              I don’t keep the brick acid in the workshop so any fume issues are not a problem. I don’t silver solder in the workshop either so makes sense to have the acid where I work.
                              Can be picked up redily from any builders merchant, screwfix, toolstation, DIY shed etc.
                              #701795
                              Dave Halford
                                @davehalford22513
                                Also known as Muriatic acid in the US
                                #701885
                                File Handle
                                  @filehandle
                                  There are many acids that you can buy, but under different names: drain cleaner, scale remover etc. Just look at the ingredients on the label. The days when you could buy oleum and dilute it with water to make sulphuric acid are probably long gone.
                                  #703219
                                  Charles Lamont
                                    @charleslamont71117
                                    Argh, NO! You add conc. sulfuric to water, not the other way round, remember!
                                    #703233
                                    Robert Atkinson 2
                                      @robertatkinson2
                                      Just to expand on JasonB’s comment, The fumes from hydrochloric acid are very corrosive. Don’t keep or use it anywhere near metal you don’t want damaged.
                                      #703308
                                      Russell Eberhardt
                                        @russelleberhardt48058
                                        Yes, hydrochloric acid and its fumes are very corrosive. It also removes zinc from brass very quickly leaving a copper surface.  Sulphuric acid is much safer to use, about 5% w.w. solution.
                                        I don’t know why sulphuric acid is classed as an explosive precursor.  You need concentrated sulphuric and nitric acid for that.  30% sulphuric acid is easily available here in France.  It is even stocked in some supermarkets!
                                        Russell
                                        #703331
                                        noel shelley
                                          @noelshelley55608
                                          For any body diluting sulphuric acid (or others) The process of dilution is exothermic and depending on concentration will make a lot of heat ! NEVER, NEVER, NEVER put water into a conc acid ALWAYS put the acid into water ! If using a plastic vessel be VERY careful,it is possible for the heat to melt the plastic with disasterous results – I was lucky, a large water tank saved the day ! Noel.
                                          #703345
                                            On Russell Eberhardt Said:
                                            I don’t know why sulphuric acid is classed as an explosive precursor…
                                            It’s classed as an explosive pre-cursor because it is an explosive pre-cursor!
                                            Mechanical Engineers tend to underestimate what other engineers are capable of.   We assume mechanical mechanisms are simpler and more reliable than electronics, steel made from recycled metal must be impure, electric cars don’t work, and many other half-true simplifications.  The truth is experts within their specialisation run rings round everybody else.  It’s what they know that matters, not what we believe!
                                            A chemical engineer knows how to manipulate Sulphuric Acid, and much, much more.   Sadly, some chemists support terrorists (or freedom fighters depending on the politics) or make illegal Class A drugs for a living.  Misuse is a real problem, and I’d rather inconvenience a few hobbyists than make it easy for persons of ill-intent.
                                            For pickling, a cheap fast acting clean mineral acid is best, and dilute Sulphuric ticks most of the boxes.  Industry use it in very large quantities, and for them the paper-work needed to buy it is trivial. Unfortunately, mad bombers have much the same profile as Model Engineers.  They order a small quantity (less than a ton) for delivery to a private address, and have no established commercial or technical purpose. Expect to be treated with suspicion.
                                            Hydrochloric Acid is also cheap, fast acting, and readily available but it’s less suitable for pickling because it leaves corrosive Chloride ions in the pores of the metal. These undermine the effectiveness of Galvanising, Paint, and other anti-corrosion treatments.  Unlikely to show up on amateur work, but it noticeably reduces the corrosion resistance of steel structures; bridges that should last 80 years, only last 50 etc.
                                            Citric Acid is slow acting and expensive, but it’s completely safe, doesn’t smell, and is readily available.  The cost doesn’t matter much in small workshop, because we rarely pickle large amounts of metal, nor do we need results in minutes.  Leaving Citric Acid overnight will do the job.  Citric Acid’s slow action is an advantage in some cases, for example it’s less likely to seriously de-Zinc Brass before anyone notices!
                                            For ordinary sized model engineering objects, I use Citric. If I needed to pickle a large amount of metal quickly, I’d buy some Hydrochloric Acid.  It’s sold by most Builders Merchants and DIY stores as Brick or Patio Cleaner, and is also used in Swimming Pools.   Not needed to yet.  If I was a professional Boiler maker, where cost and speed are  important, I’d do the paperwork and buy Sulphuric.
                                            PS I know Sulphuric is spelt Sulfuric, but I’m an old-fashioned Brit!
                                            #703363
                                            Roderick Jenkins
                                              @roderickjenkins93242
                                              Regarding concentrated sulphuric acid, a few years ago it became popular to use the acid as a disfiguring weapon of revenge and “honour” punishment.  I believe this was the real driver to restrict easy availability and adding it to the explosive precursor list was a quick and convenient way to achieve this.
                                              Rod
                                              #703376
                                              Russell Eberhardt
                                                Rod
                                                That seems a more likely explanation of the restriction rather than it being used for making explosives when sold at about 30%.
                                                Russell
                                                #703384
                                                  On the subject of Citric Acid being relatively cheap …
                                                  Anyone wishing to use it in small quantities could do worse than visit Home Bargains … They have ‘Elbow Grease’ brand in a convenient 250g screw-top tub for £1.49
                                                  Robert Atkinson 2
                                                    @robertatkinson2
                                                    I went to check the concentration of Sulfuric acid that requires an EPP licence and found that both Hydrochloric and Phosphoric acid have been added to the EPP list effective 1st Oct 2023. The relevant concentrations are:
                                                    Sulfuric acid 15% W/W
                                                    Hydrochloric acid 10% W/W
                                                    Phosphoric acid 30% W/W
                                                    As only about 5% Sulfuric acid is required for pickling it is quite legal to buy 10 or 12% and dilute it 1:1 with water. A supplier may even be prepared to make it up to this strength for you.
                                                    Ammonium nitrate, Mercury compounds and Arsnic compounds have also been added to the restricted list.
                                                    Reference:
                                                    https://www.gov.uk/government/publications/supplying-explosives-precursors/supplying-explosives-precursors-and-poison#fulllist
                                                    #703430
                                                    bernard towers
                                                      @bernardtowers37738
                                                      Michael, Thats really going to hack the home brew shops off , they are between 100% and 400% more!
                                                    Home › Forums › Workshop Techniques › Topics
