Phillips vs Pozidrive and portable drills
Home Forums The Tea Room Phillips vs Pozidrive and portable drills
Viewing 25 posts - 1 through 25 (of 49 total)
  • #35528
    Russell Eberhardt
      @russelleberhardt48058
      Russell Eberhardt
        Why do portable drills always come with Phillips screwdriver bits when all screws on sale seem to be Pozidrive? I've just been repairing a wooden terrace and been mangling half of the screws in the process as a result.
        Russell
        #417411
        KWIL
          @kwil
          Solve your "problem" by using the correct cross insert?
          #417414
            Never bough any drywall screws, self tappers, etc all generally come with Phillips rather than Posi.
            I just carry a range of bits as it's hard to tell what you may find on site be that slotted, pozi, prodrive, Phillips, Torx, square, allen and the odd tec screw
            Edited By JasonB on 05/07/2019 10:19:06
            #417415
            RMA
              @rma
              Typical example of non standardization! Having put thousands of these things in, I always find Posidrive to be the best…..and then comes along a Philips head!! Have to search and change the bit, and they never seem to bite as well.
              Single slot still around, and what a pain they are. Torx head Brilliant but not that common although I have put a few thousand of those in.
              #417418
              Russell Eberhardt
                Posted by KWIL on 05/07/2019 10:10:31:
                That's all very well but I had to visit three different DIY stores before I found the correct Pozi bit in Leroy Merlin. Perhaps it's just a problem in France.
                Russell
                #417421
                Vic
                  @vic
                  Sadly I’ve still got stock of lots of Philips and Pozidrive screws. I try not to use them though and haven’t actually bought any for many years. My preferred drive is Robertson (Square) drive. If I can’t get those then I use a Torx. I got at least one Terminal screwdriver and they work pretty well but of course you can’t buy screws with combined heads!
                  #417431
                  Mike Poole
                    @mikepoole82104
                    Just brum em insmiley
                    #417444
                    KWIL
                      @kwil
                      That's all very well but some may not appreciate what the expression meansdevil
                      #417448
                      Mike Poole
                        @mikepoole82104
                        As Kwil points out maybe not everyone is familiar with the expression ‘brum em in’. Brum is the city of Birmingham in the UK and a Brumaggem screwdriver is a hammer. The suggestion is that time is wasted using a screwdriver when a hammer will sink the screw, probably sharp practice from the days of piecework. Obviously a hammer will not be fussy about the head of the screw. These days with many screws being hard brumming them in could be quite dangerous and is not to be recommended.
                        #417451
                        roy entwistle
                          @royentwistle24699
                          My dad used to say " a hammer is for putting screws in, a screw driver is for removing them " One old chap I worked with as an apprentice used to call a screw driver a turn screw, and a spanner a nut key
                          Roy
                          #417452
                          Nick Clarke 3
                            @nickclarke3
                            Posted by Mike Poole on 05/07/2019 12:55:42:
                            As an adopted Brummie, living here for more than 30 years, I would like just like to point out that this reference to inserting screws is not correct – I am not fussy about anything and everything!
                            #417457
                            Mick Henshall
                              @mickhenshall99321
                              I only use slot headed screws, can't abide posi headed anything
                              Mick 🇬🇧
                              #417459
                              Bazyle
                                @bazyle
                                Boxes of better screws eg Reisser come with a new bit in every box so the professionals will have the fight one. I think Robertson is mostly just in Canada.
                                You can get hammer screws designed to be hammered in but have more holding power than a nail and can be unscrewed if needed. Their thread is shallow long lead and they are actually quite difficult to get to screw in.
                                #417461
                                  Ah a hammer, I remember those from the days before I put nails and pin in with gunswink
                                  Hammer just gets used to "adjust" the position of the bit of timber these days, can usually get it good to the nearest nano or two.
                                  Talking of knocking timber into position I'm part way through redoing a lot of work on a gym and changing room extension to a swimming pool where the previous work left a lot to be desired and resulted in chronic condensation within the roof voids. Now that the finished building has been stripped back to bare studwork, joists and rafters and allowed to dry out several of the ceiling joists have dropped out where they were hammered in tight when the wood was fresh and moist from the yard and the cowboys forgot to nail them in.
                                  #417462
                                  Jeff Dayman
                                    @jeffdayman43397
                                    "I think Robertson is mostly just in Canada"
                                    Uh, no. Very widely used in USA (sometimes under the Scrulox imitator brand) and south America also. THE best head and driver design in the world, bar none, for wood screws. Try them and you will never go back to other kinds.
                                    They were invented in Milton Ontario Canada by Mr P L Robertson. He had a plant for making them in UK as well, in the 1920's-1930's.
                                    #417465
                                    John Reese
                                      @johnreese12848
                                      Robertson heads are quite common in the US also. We see some screws with a combination head: Robertson and Phillips. They seem to strip out more frequently than either the Robertson or the Phillips. The higher grade fasteners are mostly Torx drive now.
                                      #417469
                                      Georgineer
                                        @georgineer
                                        Posted by Jeff Dayman on 05/07/2019 13:38:32:
                                        That makes sense. The only time I have encountered them in the UK was on a wooden step-ladder I inherited from my grandfather. I estimated that it dated from the 1920s or 30s, and it took me a long time to identify the screw heads. Sadly, the step-ladder succumbed to the combined effects of damp and woodworm some years ago.
                                        George B.
                                        #417470
                                          Posted by Nick Clarke 3 on 05/07/2019 13:04:59:
                                          In my 'O level' Woodwork exam … one of the written questions was:
                                          A hammer is for putting-in screws, a screwdriver is for removing them: Discuss
                                          Note: I may have paraphrased the question, but that was certainly the essence of it.
                                          #417474
                                            The most common use of square drive screws in the UK is for pocket hole joinery where "kreg" are the common brand made popular by Norm on NYWS. That's about the only thing I use them for, driver does tend to stay in the hole well.
                                            #417476
                                            Vic
                                              @vic
                                              I first saw them when I went to Canada on holiday 20 years ago. The salesman in a DIY store (an Australian!) was surprised I hadn't seen them before. I came back with several boxes of screws, screwdrivers and bits. Beware of Makita brand bits though, they don’t fit! I sent them back to Makita with some screws and a complaint but they never replied. You can get the screws and drivers etc from:
                                              Square Screws UK
                                              For fittings where the screw is on display, like coat hooks for example Square drive look so much nicer than Pozidrive screws.
                                              #417504
                                              old mart
                                                @oldmart
                                                As soon as you use posidrive or phillips in an electric drill, it becomes normal to have to throw away the bits after every dozen screws. I always buy my pozidrive #2 bits in boxes of 25 at Screwfix. They are made of "S2" steel, whatever that is.
                                                The square drive screws are excellent, although I personally favour torx.
                                                #417505
                                                Robert Atkinson 2
                                                  @robertatkinson2
                                                  It's not just simple Phillips / Posidrive. Two fairly common variations are the Japanese JIS which is close to phillips but less pointed. Then there is Supadriv which neither Phillips or Posidriv fit properly. JIS headed screws are often identified by a dimple on the head.
                                                  More esoterically there is RIBE/Polydrive (used on FCA nd GM vehicles) and Spline which look a bit like Torx. As an aircraft engineer I have also had to deal with Bristol spline TorqSet, Triwing and Hi-Torq.
                                                  Robert G8RPI.
                                                  Edited By Robert Atkinson 2 on 05/07/2019 19:33:22
                                                  #417507
                                                    Posted by old mart on 05/07/2019 17:04:20:
                                                    Well there is your problem, a box of Sh**2 bits will not last as long as a single decent bit costing more than the box full of Titan brand
                                                    #417512
                                                      Posted by Robert Atkinson 2 on 05/07/2019 17:07:42:
                                                      Do you happen to know of a reasonably priced supplier [to the UK]
                                                      … I have a set of small keys, but need a couple of larger ones.
