Hi David, glad that was of use.
The levers operate the drain cocks. These drain through those two pipes emerging from under the cover direct into the exhaust system. This inturn exhausted into a ‘temporary’ sump – the ubiquitous tobacco tin which along with so much else never did see an improvement!
The engine was not built from a standard kit but from just the main basic castings purchased from ST. This was when they were at Henley so that dates it (and me) a bit
The ‘extra bolts’ and other small embellishments then were just an attempt to make it a little more scale like but those (relatively) out of scale flywheel rope grooves done to ST dimensions always niggled once the ‘clash of scales’ was noticed.
The two ‘blocks’ on top of the steam chests were milled from brass and contain two shuttle valves which are lifted/lowered by crankpins running in a groove on the valves. The two are couple together and activated by the governor. This did work after a fashion but the valves really needed a finer taper on them.
Over the years this was displayed a list of improvements/mods etc to be carried out gradually grew but other than starting some pedestal oilers for the big ends which along with the list still languish in a drawer something else always seemed more important.
It may be of interest to know that the ‘glass’ oilers are made from small sections of that crystal clear tubing that is sometimes used to protect the bristles of new artist’s paint brushes. Pushed on to a brass mandrel turned to fit the ID it is then very easy to part off to the length required.
Hope that helps a bit more – there are a few more pics should you desire however I don’t wish to crowd your thread
Regards – Ramon
