Posted by Nicholas Farr on 02/04/2020 10:41:51:
Hi Simon, personally I see no safety aspects of these cards, the instructions a very clear and any fuse rating on the card only tells you what value the plug is supplied with and can be changed. To be frank, if you can't understand how to fit a plug, then you should not attempt to do it. As far as fitting the plug, the wiring is the same regardless of the fuse rating on the card and the card can and should be removed once the plug is fitted, however I see no risk in leaving it on providing the fuse rating stated on the card is the same as that which is fitted in the plug.
Regards Nick.
Ah, not the point I intended to get across…..duh!
I have no issue whatsoever with the printed content on the card, rather the fact that a piece of cardboard is trapped between the plug body and the socket and wondering if it conforms to all the flash and tracking criteria that I believe apply to the plastics used in the plug bodies.
So, how much of a safety (fire?) hazard is a piece of cardboard especially if it became damp is my amended question.
Simon
