If you go for a DOL, you will find it is built for 3-phase use, with 3 connectors, 3sets of coils etc. where the inputs are L1, L2, L3 and the outputs are A, B, C. It will still be fine with single phase and just needs a link from say input L2 to output A. Then connect your input to L1 (line) and L3 (neutral) and take the outputs from B (line) and C (neutral).
If you already know this, apologies, just thought it might be worth noting in advance. The above is the scheme recommended by Tubal Cain in his "Model Engineer's Handbook", and is what I have used several times.
Phil
