Myford Super 7
Myford Super 7
Home Forums Manual machine tools Myford Super 7
Viewing 7 posts - 26 through 32 (of 32 total)
  • #99840
    KWIL
      @kwil
      No problem with bushes, look on Bearingboys website for all sizes.
      DMB
        @dmb
        Sparky,
        There are a couple of parts of your lathe which suggest to me that it is not an MLS7 but possibly an ML7R. I have a similar grey Myford and its a genuine S7. Id has different headstock bearings – yours look like ML7 style. Your leadscrew protector appears to be the tubular type. Mine is a short length of flat bar bolted to the end of the saddle at an angle to create a slope, making swarf + coolant run off.
        What do you think?
        DMB
          @dmb
          Sparky,
          What do you think?
          sparky mike
            @sparkymike
            Thanks Kwil, I will check them out for bushes. I need another bush for another project so two bushes will not make the postage seem so high !!
            John. I have checked out many Super 7's on various sites and they all look like mine. I thought that the ML7 had removable caps on the headstock bearing? The swarf cover is of the telescopic type and was used on the earlier sevens.
            As mine is a very early one could this be giving you the wrong impression?
            Mike.
            #99884
            DMR
              @dmr
              Mike,
              Your efforts are certainly impressive on this.
              There is no wick down the oil hole in early drip feed machines!
              Earliest countershaft/clutches ran on needle roller bearings and that is how you have picked up on the noise aspect. Yours clearly has had the bushes retrofitted at a date after manufacture. It was a Myford offer for all the early machines which became noisy; but not a free offer. A noisy countershaft would still work fine with no noticeable play, but sounded awful.
              Dennis
              #99887
              sparky mike
                @sparkymike
                Hi Dennis, the worn bush is on the leadscrew, not the countershaft. My needle roller bearings are fine and quiet on the countershaft so I will leave them well alone for now.
                Mike.
                #100027
                mike mcdermid
                  @mikemcdermid41977
                  mines the same as mikes and has the noisy needle rollers
                  Ive kind of learned to love the rythm they make as they go round
