Well at last I have the lathe running !! It still has to be boted down to the stand, once the drip tray is fabricated. I am impressed how quiet it is and the clutch is a very handy facility that I am not used to. The clutch is so far not making any noises, as I understand that the early clutches like mine are prone to do.
The new oil sight glass is now complete and working as intended. The removable front is a good tight push fit into the tube type holder and the actual sight glass was turned up from Perspex rod, which I found easy to turn and not as tricky as I had been led to understand. I re-polished the ends after facing, with a cloth soaked in Brasso while turning at a fairly high speed.
Regarding the oil feed, there was no wick in the drilled hole that goes to the front bearing. Should there be one on the early lathes with sight glass ?
One small point, the leadscrew is making a noise when turned by hand, that I can't pinpoint at the moment. It sound like it is binding slightly, but all points are well oiled so any advise here would be helpful. I have slackened and retightened both leadscrew brackets in an attempt to line it up better, but this makes no difference.
The QC gearbox is not complete yet but I am making slow progress on it day by day.
Link below to photos
.**LINK**
Edited By sparky mike on 01/10/2012 08:51:00
