Helping a newcomer to our hobby here in Johannesburg, I have just inspected an old S7 (serial number 78745) which overall is in reasonable condition except the teeth on the bronze backgear. Compared to my own more modern S7, the bronze teeth are both worn and chipped in places. (The other backgear teeth, the 17T/53T cluster and the 60 T are in good shape)
It is not clear from the Myford manual how the vee cone pulley / bronze backgear assembly is put together.
What options does he have should he want to retain the use of the backgear to get low speeds? The backgear works at present, but I would think that failure is not far off!
I did point out that he could avoid using the backgear by fitting a VFD as one solution.
Thanks for any help.
Dennis
