Thank you Gentlemen,
My first and previous lathe was a Super 7 with an oiler, I loved it because I could set the pin point screw to allow a drip of oil, the best thing was I could see it working.
I would hate to run the bearing dry and most likely used more oil then necessary.
The new oil system, I cant see if the oil is getting freely to the bearing, I did not know about the air hole mentioned above.Taking the spindle out to see if it is working is a serious business.
I didnt know the spindle had to come out to see if it was wicking correctly.
My lathe is only a recent up grade made in 1986, my previous was made in 1952 and still a beautiful machine.
