Myford lathe beds,
Myford lathe beds,
Home › Forums › Beginners questions › Myford lathe beds,
  • #46800
    Charlie,
      @charlie18171
      If one needs to have induction hardened bedways reground will the hardness be reduced or lost altogether?,
      #4898
      Charlie,
        @charlie18171
        Regrinds,
        #47144
        Robert Thomas 3
          @robertthomas3
          charlie,
          Be aware, if you are planning work by a firm other than Myford’s, that Myford intentionally stress the bed to produce a very slight curvature during their grinding operation. I don’t recall the details other than the deviation from linearity is only a thou or so. The process was described in the SMEE Journal in relation to a field trip to Myford’s the society had taken in the the last few years. It might be worthwhile to discuss your needs with Myford.
          Regards, Bob Thomas
          #47145
          mgj
            @mgj
            Charlie – you will have to talk to Myfords to ask about the hardening. Some  hardening just does the surface, other processes can through harden, and you don’t know what the prehardening treatment is like. They could chill after casting so the bed is pretty hard anyway, and so forth.
            #47188
            Charlie,
              @charlie18171
              Thank you chaps for your input to my question,And i can see now that the definitive answer is a bit more complicated than i antisipated,My knowledge of hardening dose
              not extend beyond soaking an item in Kasenit overnight,Have a good new year and thanks,
