Myford fit collets
Myford fit collets
Home › Forums › Workshop Tools and Tooling › Myford fit collets
  • #451754
    paul humphries
      @paulhumphries17598
      Hi,
      I am thinking of a collet set up for a ML10 . I am mainly going to hold small gears etc for boring out rather than holding tools so I am leaning towards ER 25 on a backplate rather than using the MT. Is this the best way to go? I know i will have to machine the backplate but I must confess to being slightly confused as to which parts to machine.
      Paul
      #19623
      paul humphries
        @paulhumphries17598
        #451758
        David George 1
          @davidgeorge1
          If you grip jobs in a ER collet it needs to be tightened very tight or it won't run true and very short jobs won't grip properly. What type of gears are you making diamiter and thickness.
          David
          #451771
          paul humphries
            @paulhumphries17598
            Hi David about 16 to 20mm worms and spur gears that need to be reamed.
            Paul
            #451780
            JohnF
              @johnf59703
              Assuming the ML10 has an MT2 in the spindle then the ER collets are your only option, however I would consider ER32, that what I use on my Super 7. The ER25 will not hold your 20mm dia components.
              John Haine
                @johnhaine32865
                I have an ER40 chuck on a bib-bore 7 but the principle is the same.
                The backplate screws on the spindle nose just like a standard chuck backplate.
                There is an oversize register on the backplate that you then machine concentric and a very good fit (slightly tight) into the recess on the collet holder part.
                Then bolt the holder part in place and you're good to go.
                Buy a ball bearing collet closer to make it easier to get good clamping force.
                #451785
                paul humphries
                  @paulhumphries17598
                  Thanks John.
                  #451803
                    Posted by JohnF on 11/02/2020 21:21:08:
                    Should not be a problem to fit a 5C chuck to the Myford, I have held spur gears in my 5C collets a number of times and they grip at the end.
                    Another alternative would be to get some soft jaws for your existing chuck that can be machined in-situe and give the best contricity of all the options, again that is how I hold larger spur gears. A slight step in the soft jaws make sit easy to eliminate any wobble that you can get when gripping by just the edge.
                    If you do go with ER then you will need to make a plug to go in teh back end so they close down parallel onto the spur gear
                    Edited By JasonB on 12/02/2020 07:30:20
