Posted by Nick Hughes on 23/01/2016 23:11:50:
Brian Wood, the 600-82942 Kit that Newall supply to fit a Myford, DID have a scale that is too short for a Long Cross Slide (by 2"/50mm using their brackets), as I personally experienced in 2015.
Nick.
Edited By Nick Hughes on 23/01/2016 23:30:31
Hello Nick,
Clearly something has changed since the time I bought my lathe DRO package in 2002. I took advantage of the joint collaboration Newall then had with Chester UK [as they were then called] and I feel sure mine was one of the early supplies for a Myford ML7 lathe. I was visited by Brian Mosley, who was the regional sales manager for Newall. He took measurements and I was supplied with a Sherosyn scale down the bed having a travel range of 450mm and one to suit my long cross slide with a travel range of 200 mm.
The display unit is a Digipac, heavily based on the phased out Sapphire model that Newall had supplied for many years to industry
I went back to Newall the following year to equip my Dore Westbury mill and again had the pleasure of a visit from Brian Mosley. This time the scales were 300 and 175 mm travel for the two axes. the display is a Topaz two axis unit having the PCD function.
I have been delighted with both systems and was very pleased to meet Brian again on the Chester stand at Harrogate in 2004. He had by then shed a great deal of weight and looked a much fitter man entirely. I think the association between the two companies came to an end that year, Newall didn't feature at all in 2005
I hope the information is of interest to you
Correction. All the scales and readers are Microsyn units, my apologies Brian
Edited By Brian Wood on 25/01/2016 19:20:11
