MT1 Reamers
MT1 Reamers
Home › Forums › Beginners questions › MT1 Reamers
  • #9677
    Lainchy
      @lainchy
      #410700
      Lainchy
        @lainchy
        Hi Forum,
        I'm an engineering "noob" so be gentle plz
        I'm just in the process of setting up a workshop after purchasing a bargain WM14 mill. I'm looking at a WM180 lathe, and then some beginner projects… but, my mill has come with a good few bits, including some reamers that are MT1.
        My question is this… How would I hold the MT1 Reamers? I've seen the MT2 to MT1 converters, which seem fine for the tailstock of a lathe, but if I wish to use them in the mill, which has a captive drawbar (M10 and 3/8) I'd prefer an MT2-MT1 converter, and that doesn't seem to exist.
        The Reamers don't have a thread in the back for a drawbar, and I assume that this will be removed from the adapters with a slot and key, but how can I fit them in the mill?
        Many thanks
        Ian
        #410767
          Welcome to the forum Ian,
          If the reamers have a tang, then you will probably need a tanged and slotted adaptor, which won't take a drawbar.
          Because there are no side loads on a reamer, you shouldn't need to use a drawbar (most MT socket drills don't have drawbars).
          This does mean you will probably have to remove the drawbar to use the reamer.
          Edited By Neil Wyatt on 24/05/2019 22:10:47
          #410796
          Lainchy
            @lainchy
            Thanks Neil. Much appreciated. I'll see if I can grab one of those for the box.
