The advert has no technical detail, not even obvious it’s a replacement starter motor for certain Yamaha motor bikes. I don’t think it can can be sensibly reviewed unless it’s fitted to a bike.
Starter motors are designed to deliver a lot of power and torque in short bursts. They have to crank a heavy engine up from cold and spin it steadily until the fuel ignites and the engine runs on it’s own. Typically less than 5 seconds unless something is wrong.
One of the alternative motors offered has more information: power output = 1.4kW and 12A at 12V. On the face of it, 12V x 12A = 144W, not 1.4kW! However, I think the numbers are a simplification. The motor draws about 120A when the starter button is first pressed and then outputs 1.4kW to accelerate the engine quickly up to cranking speed. Once the engine is turning fast enough, the starter motor drops to about 12A, sufficient to keep the engine turning until the fuel fires.
I can’t think of an obvious workshop application for a starter motor – they are too specialised! What tool needs a motor delivering 1.4kW for a few seconds, idles at 144W for several more, and then needs a long rest to cool down? A punch maybe? Dunno.
The power supply is another complication – hard to find a mains power supply that can deliver 100A without spending big money! Powering a starter motor on a bike isn’t a problem because vehicle batteries are designed to deliver lots of amps in short bursts. Powering it in a workshop is a problem to be solved.
Windscreen wiper motors are much more useful. They run from an ordinary supply with enough continuous power to wind tables, lift heads, and maybe drive a small reciprocating saw etc. But these days, they might not be top choice because new steppers and brushless motors are competitively priced. Rather than mess about adapting a surplus motor, buy one of the correct specification with a controller and power supply. Whichever is easiest.
