Posted by ronan walsh on 17/10/2013 01:33:48:
I also thought the sticking might have been caused by me not removing the chuck from the machine often enough, <etc.>
Ronan,
The sticking is a "Design Feature" of the Morse Taper … it is, by design, a self-locking taper.
As others have mentioned; it was originally intended for drilling, where the only loads are axial and torsion. … In this situation the taper should "lock" and will need ejecting in some way.
The problem with using MT on a mill is the side-loads; which tend to "walk" the taper-fit apart.
Fundamentally; Using MT on a milling spindle is bad design, and therefore we resort to excessive drawbar tightening; which then results in the other problem.
A proper taper for a mill is self-releasing, and always needs to be held in firm contact with a drawbar.
Your problems are simply down to the design compromise that was chosen for your mill.
It appears that your MT is an excellent fit … so; Use the lightest drawbar tension that still prevents the taper "walking apart", and have a look at impact-free methods of extraction.
