More collet and milling tools confusion.
Home Forums Beginners questions More collet and milling tools confusion.
Viewing 6 posts - 26 through 31 (of 31 total)
  • #375279
    Farmboy
      @farmboy
      My point about the cost was that you don't need to spend around £50 on an ER chuck if you have a Morse taper lathe spindle. I have bought several MT3 collets very cheaply in clearance sales from various suppliers, presumably because there's not much demand for them, and have used them successfully. I also had good results from a fly cutter on MT3.
      If money is no object by all means go for the best you can get, but there is a lot you can do with a little ingenuity and minimal equipment, as ably demonstrated in Neil's earlier post.
      Mike.
      MW
        @mw27036
        Posted by Farmboy on 09/10/2018 22:41:59:
        It might seem like a benefit at first but i envy the MT3 size over having an MT4 spindle, which is so awkward because those size collets are either expensive or rare as hens teeth.
        my only option is to make one myself if i'm able to which will be true to the lathe, but making it true to a nominal dia. might be a different trouble altogether!
        These combined factors would make ER actually desirable for a large spindle bore in my opinion, plus i can swap them out to use on the mill.
        Michael W
        Edited By Michael-w on 19/10/2018 20:42:23
        #376719
        andrew lyner
          @andrewlyner71257
          Just to give closure on my situation, I got an ER 25 collet chuck on a 100mm flange which fits right on the lathe flange. It was only £40 and I now have just one 6mm collet and 6mm end mill. I shall buy things as and when I 'need' them. One day I may even put work in a collet and there is a useful range on each collet.
          PS those ER style collets are pretty damn clever with the interleaved cuts. They give you even pressure all along the contact with the tool. Worth buying even if just to sit and watch the way it works!!!
          #376735
            Posted by Michael-w on 19/10/2018 20:40:10:
            Why do't you just buy a MT4-MT3 sleeve, same applies to the other big bore lathes which tend to come with an adaptor . Think mine came from ARC
            #376800
            MW
              @mw27036
              Posted by JasonB on 20/10/2018 07:02:51:
              It's a good idea, i have got a 4 -2 step down, i think from arc too, and i tried one of those collet chucks to it and it still gave me poor runout,(0.15mm) i think they have a bit of a reputation for.
              I have never tried actual spindle collets in them though, maybe they're a cut above the typical bunch. It could be my collets too they're not branded but came from RDG or ARC.
              I take it you'd need a bloody coarse thread to tighten up an MT4 collet if it could exist? 😛 I used M16 to make a drawbar for an ER40 taper chuck.
              This is really on the backburner but i was planning to ditch the taper idea altogether and go with a flange mounted chuck, in the vain hope i might get better result.
              Obviously the only way to guarantee a totally concentric part is to turn between centres but a collet chuck has it's useful moments for when you need to work on the opposite side of a part in two stage turning operations.
              Edited By Michael-w on 20/10/2018 15:37:25
              #376849
              Howard Lewis
                @howardlewis46836
                FWIW:
                My lathe has a 5MT mandrel, into which goes a MT5 -3 open end sleeve. Into that goes a 3MT ER25 or ER32 collet chuck, retained by a 3/8 BSW drawbar (The M12 thread in the collet chuck has been sleeved down to 3/8 BSW, if anyone wonders! Could have made up a M12 drawbar, but the same collet chucks also do duty in the Mill which has a very narrow bore in the quill.
                Definitely a fan of ER collets, for many years. They can accommodate , in the larger sizes a 1mm size difference,(0.5mm in the smaller sizes < 4mm) so will take Metric or Imperial tooling.
