Ok so… I have a problem with my indicator, i purchased it secondhand and all it needed was a bit of WD40 and a clean up. Perfect… so i did that and its been working fine or so i thought… Its accurate don't get me wrong, i checked it against a set of slip gauges however if i tilt it left to right it moves around 0.05mm
Has anyone else had this problem? I took the side case off to see if anything was loose or broken and all looked fine. Its a Mitutoyo 513-204 lever indicator. As i said accuracy doesn't appear to be effected and when its on a stand and i press the stylus up and down the needle returns to the same spot however if i tilt it left to right the needle sags/ moves? I thought about sending it to Mitutoyo but i only paid £10 for it and i would imagine the repair bill would be 3 times that so I'm hoping i can fix it at home?
Hope someone can shed some light
Steve
