Hi,
Not so much an idea about where to obtain a replacement motor, but more an idea about what to get – if you see what I mean.
I can't remember what the nominal speed is of the existing motor, but if possible, how about a 2-speed motor – one speed being the normal speed, with the other being a slower speed. This would then allow for a reduction in the minimum speed of 125rpm which would make screwcutting under power easier.
Alternatively, how about going 3-phase, apparently much smoother and can also have variable speed along with a jog facility.
Or finally, go DC along the lines of other lathes and milling machines, eg my MiniMill has a 500W DC motor – the 220 has a 550W AC motor so not much difference there in power but can be speed controlled. Apparently the Seig or equivalent controllers, and I assume motors, are available as spares.
In fact, a combination of speed control and the existing belt arrangement would mean that the actual speed control range could be limited which would simplify the control arrangements and would not result in as much torque loss.
As you may gather, I have a 220 lathe and the possibility of achieving a lower speed range down to say 15rpm or so has long intrigued me.
As I say, just some random thoughts.
Peter G. Shaw
