Minnie Traction Engine – Rotary Lathe Cutter
Home › Forums › Beginners questions › Minnie Traction Engine – Rotary Lathe Cutter
  • #348771
    Malcolm Farrant
      @malcolmfarrant93389
      I need to make a rotary cutter for the various 'curved castings' on the Minnie
      I may well have asked this question before, but seem to have lost it apart from the post from Brian O'Conner.on 27/9/2017
      I am almost at the stage of needing this.
      1. What diameter rodr is recomended ?
      2. What diameter cutter should I use ?
      Needless to asy any other bits of advice are very welcome.
      Edited By Malcolm Farrant on 04/04/2018 11:32:03
      #9150
      Malcolm Farrant
        #348775
        Oldiron
          @oldiron
          I am sure that there are many machinists on this forum could give you an answer. I am not sure how many have all the dimensions for Minnie castings. A little more info' would be of great help. I can only say that the heavier and more rigid the tooling you use the better the job is likely to turn out.
          regards
          #348777
            Are you talking about a cutter to do the curved underside of the cylinder and chimney base?
            #348791
            Malcolm Farrant
              JasonB,
              Yes that is correct.
              There is no very hard material to turn, but I need to do a good job of it.
              Please give me ideas for the way forward !
              Best wishes
              Malcolm
              #348795
              Richard S2
                @richards2
                Hello Malcolm, Your original post on this is here-
                LINK
                If you need any more info on a 'Between Centres' Boring Bar, I'll sort some dimensions of the one I made.
                #348797
                  Well I would say that the other post was about traditional flycutters that are more often used for machining flat surfaces though they can be put to use doing curves and so can boring heads. Though having said that Mason also calls the between ctrs bar a flycutter.
                  I would suggest a bar of 3/4" to 1" diameter and a square or round tool bit of 3/16". Drill across the bar to take the tool bit and then at right angles to that hole for a screw to retain the cutter.
                  Something like this can be driven by a chuck and the other end supported with the tailstock ctr.
                  #348798
                  Malcolm Farrant
                    JasonB, Yet again thank you,
                    I think that gives mr all i need to make progress.
                    Best regards
                    Malcolm
                    #348800
                    Richard S2
                      @richards2
                      I'll get my coat !.
                      #348801
                      Russell Eberhardt
                        @russelleberhardt48058
                        If you drill for the cutter at about 80° to the axis rather than 90° it is easier to measure the cutting radius accurately with calipers at 90°.
                        Russell
                        #348871
                        Malcolm Farrant
                          As always thank you all for your comments. It is now up to me to get it right !!!
                          Regards to all
                          Malcolm Farrant
                          #349846
                          Malcolm Farrant
                            HELP PLEASE I'm back again.
                            I have the round bar, and 3/16th tool steell I need to creat my Fly cutter, all I need now is to what profile should i grind the tool.
                            Is it a simple V shape or or os it ground at any spesific angle.
                            Perhaps there is a suitable link I can find on google ?
                            Best wishes
                            Malcolm
                            Edited By Malcolm Farrant on 11/04/2018 18:46:00
                            #349864
                              Assuming the work will be fed towards the chuck then you want the toolbit ground up like a lefthand hand turning tool. Something like this but when you come to mount it in the bar have it upside down pointing facing towards you.
                              #349902
                              Malcolm Farrant
                                Jason, many thanks for that. I will now try and make the tool. I will then test cut, before doing any actaul casting. !!
                                Best wishes
                                Malcolm
                                Edited By Malcolm Farrant on 12/04/2018 09:23:29
