Mini-lathe dying..?
Mini-lathe dying..?
Home Forums Manual machine tools Mini-lathe dying..?
Viewing 25 posts - 1 through 25 (of 31 total)
  • #13344
    Ron Laden
      @ronladen17547
      Ron Laden
        @ronladen17547
        I fear my lathe may be on the way out, the speed control is not as it should be.
        If I dial it straight up to approx 1250 rpm of more it goes straight there and is stable. At lower speeds it fluctuates and takes about 10 seconds or more to settle on the selected speed. Also when the speed control is turned to minimum it doesnt stop, but runs on at a low speed for quite a few seconds before stopping, so something has changed.
        I suspect the board is faulty, there is only 6 month warranty on the electronics which expires next week, so better ring the supplier.
        Just my luck, damn it.
        #380998
        Brian Wood
          @brianwood45127
          Hello Ron,
          In the old days, that was the characteristic behaviour of a dirty track on a potentiometer and a drop of switch cleaner into the guts of it combined with sweeping it back and forth over the full travel was often enough to correct the problem
          Whether or not you can do that in this case I don't know, but you have little to lose in trying it before blaming the board.
          #380999
          Brian G
            @briang
            Posted by Brian Wood on 17/11/2018 08:27:31:
            …Whether or not you can do that in this case I don't know, but you have little to lose in trying it before blaming the board…
            Personally, I would contact the supplier first if the machine is still in warranty, as they could consider that attempting to fix it voids the warranty.
            (another) Brian
            #381000
            not done it yet
              @notdoneityet
              I agree with the second Brian. The supplier may know, or need to be aware of, the problem. There may be a whole consignment with dodgy pots.
              #381002
              Ron Laden
                @ronladen17547
                Hello Ron,
                Well you have made my weekend Brian..smiley you were spot on, I have just put a couple of drops of contact cleaner into the pot turned it back and forth a few times and problem solved.
                Thanks a lot Brian, very much appreciated.
                Ron
                #381006
                larry phelan 1
                  @larryphelan1
                  Brian,is there no end to your talents ?
                  A friend of mine came across something similar a while ago,same problem,same answer. It seems these these things are prone to this. One of the reasons why I dislike electronics,apart from the fact that I dont understand them anyway.
                  Gear boxes and belt drives,I,m OK with them,but the other stuff—————-??frownfrownindecision
                  #381010
                    I think it sometimes comes down to the conditions in the workshop which may affect the pot. Can't all be prone to it as my mill one is still OK after 11 years and the lathe 9yrs.
                    #381012
                    not done it yet
                      @notdoneityet
                      It may well have solved the immediate problem – but for how long? I’ve cleaned pots before now and some have lasted, but others have eventually succumbed … and sometimes not much later …
                      Good luck with your dodgy pot. The enclosure should be sufficiently dust proof, to keep out rubbish for a lot longer than 6 months.
                      #381013
                        Posted by larry phelan 1 on 17/11/2018 10:03:58:
                        … same problem,same answer. It seems these these things are prone to this. One of the reasons why I dislike electronics,apart from the fact that I dont understand them anyway.
                        Sorry to ruin your weekend Larry, but the electronics didn't fail. The part that went wrong is mechanical. When you turn the knob, a sprung contact sweeps along a curved resistive track. Being mechanical, it often goes wrong.
                        Ron's problem on a new lathe sounds like dirt on the track – perhaps metal dust from cutting. My mini-lathe had a hole in the control box where it went over the leadscrew. Bad design because it allowed swarf inside where a streamer of aluminium dropped on the electronics could blow the board! Newer mini-lathes are fitted with a grommet. Might be worth Ron checking that dirt can't get inside the control box.
                        Joseph Noci 1
                          @josephnoci1
                          It all depends on the type of resistive track in the potentiometer – most likely the pots typically used in these inexpensive applications is a simple carbon-ink/varnish screened or printed onto the phenolic resin base. That type of track has a life cycle at best of several hundred rotations.
                          Cermet based resistive medium can give around 50,000 rotations, and the best for this sort of application, a conductive plastic medium, capable of around 1 million cycles or more..Same material as is used in the pot in modern car gas-pedal controls. A good quality 10kOhm conductive plastic linear pot will only cost between US $5 and $15 ( the latter a sealed pot – better for this application) , so I really don't understand why the mnfr/suppliers skimp on this item! The drama caused by its failure does not warrant the cost saving.
                          Joe
                          #381018
                          Brian Wood
                            @brianwood45127
                            Larry,
                            I can't claim to be other than just another bodger really, but with a few miles under my belt!
                            There is a PM waiting for you to complete the definition of gear sizes, this covers Module versions
                            Edited By Brian Wood on 17/11/2018 10:54:11
                            #381019
                            Ron Laden
                              @ronladen17547
                              Thanks guys, I did think that the pot is probably not of the best quality or maybe not a good example when manufactured. The electrics box is open at the bottom for the leadscrew as Dave explained but at least there is a plastic cover screwed in to cover the board and all the lower electrics. The pot is situated at the top of the box and there was no evidence of any dirt or swarf visible. There was some swarf in the bottom of the box but not much and none had got behind the plastic cover.
                              The pot would be really easy to replace and as Joe suggests a sealed better quality one would be a good idea.
                              I will see how it goes and should it play up again I will replace it.
                              Ron
                              #381021
                              Samsaranda
                                @samsaranda
                                Joe
                                Anyone who has worked producing items in an engineering company will be well aware that overall control nowadays is in the hands of accountants, there is no choice when a range of costs are presented for an item where they all execute the same function, the cheapest item is the one that purchasing will be instructed to acquire. In the case of a budget priced lathe or mill then costs are paramount in the equation as profit margins are very slim.
                                Dave W ( Thankfully now retired Engineering Quality Assurance Manager )
                                #381023
                                Joseph Noci 1
                                  @josephnoci1
                                  Dave W – I realise that for sure, but still – The cost of a comeback to , for example, a supplier in the UK who sources these lathes from the east, is surely a lot more than the cost of the pot! And so I would have hoped that said supplier would 'insist' on some level of built-in preventative Quality. Ron's problem with the pot is not the first on this forum,or the tenth, so should not be to difficult to determine where cost of failure lies in a product..
                                  Joe
                                  #381024
                                    Posted by SillyOldDuffer on 17/11/2018 10:31:06:
                                    Tell me about it… happened to my CL300M, I converted it to a VFD and 3-phase motor but used teh same control box, with added grommet.
                                    Neil.
                                    #381025
                                    Brian Wood
                                      @brianwood45127
                                      Some organisations learn from this kind of penny pinching bean counting experience in the hardest way.
                                      In the early days of RB 211 production at RR in Derby, electron beam welding was a new process that was used to weld up the titanium alloy compressor drums for this new range of engines. It had the advantage of making very good welds in narrow access areas, and with the process carried out under vacuum, the welds were clean as well.
                                      One drawback was that a sacrificial back plate in matching alloy was needed to mop up the beam as it passed through the target section to avoid impingement on the remote side of the drum. The first production run of a number of drums was sanctioned after successful trials and these were found to be contaminated with a brittle Fe/Ti eutectic that could not be sorted good from bad, it wasn't even magnetic. The only test that revealed it was that it rusted when wet.
                                      Management was hard pressed at the time to meet cost pressures and were NOT impressed to find that mild steel backing plates had been substituted, without reference, in the re-order for material. The whole batch had to be scrapped out of hard, it cost the company the thick end of £1/4 million.
                                      A very expensive mistake
                                      #381029
                                      Michael Cox 1
                                        @michaelcox1
                                        Posted by Ron Laden on 17/11/2018 11:01:10:
                                        Ron
                                        The pot is actually quite difficult to source because the switch at the back turns off, ie contacts open, as the control knob is turned clockwise. This is the opposite of most normal posts where the contacts close as the control knob is turned clockwise.
                                        #381032
                                          Posted by Michael Cox 1 on 17/11/2018 13:13:15:
                                          Ron
                                          My switch broke after about ten years use, I found a company that made a suitable replacement. I rang them up and they said they only sold trade quantities, so they sent me one FOC! Sadly I don't remember who they were.
                                          Joseph Noci 1
                                            @josephnoci1
                                            Not sure what resistance your pots need be, but from 1kOhm to 50kOhm, conductive plastic, BOURNS product – also from TE-Connectivity ( both via DigiKey UK )
                                            BOURNS P/N – 56AAD-C28-B15/R81L with a SPDT switch, so ON or OFF at rest – $8.00
                                            BOURNS P/N 3310H-003-104L, same DPDT sw -$13.00 ( a beefier pot)
                                            Odd to use a pot with a switch working that way – They are not the most common which I would think makes them costlier as well. So then why did they not fit a decent one to start!
                                            Joe
                                            Edited By Joseph Noci 1 on 17/11/2018 14:14:29
                                            #381043
                                            Ron Laden
                                              @ronladen17547
                                              Hi Joe,
                                              Thanks for the part numbers, RS Components stock the 56AAD part number, cost £8.26. The lathe suppliers replacement pot is rated at 4.7K according to their website. I know little about electronics so dont know if the 4.7K needs to be strictly adhered to.
                                              Ron
                                              #381051
                                              Joseph Noci 1
                                                @josephnoci1
                                                Ron,
                                                1k and 10K are the most commonly used pots so their prices are good – there are no inexpensive 4.7kOhm pots with switch in a conductive plastic or cemet that I could find ( found some in Hi-Rel products – over 80 Pounds ea..)
                                                You could comfortably use a 5k pot though – Bourns 86R2A-R16-A13/R51L, but pricey – $25.00
                                                A neat trick – use the 56AAD part and at the same time buy a 10k 1/2 watt carbon resistor, and place it in parallel with the pot, ie, connect to the pot outer terminals – the lathe electronics won't know the difference.
                                                The 10k pot may well work with your lathe, but adding the 10 cent resistor makes that you don't have to think about it.
                                                You could just buy the maker's replacement pot, but with the 56AAD part, at least it should last the lathe's life.
                                                Joe
                                                #381054
                                                Ron Laden
                                                  @ronladen17547
                                                  Thanks Joe I will give that idea some thought, the suppliers pot is over £10 so its not as though it is cheap especially when you consider there could be a question mark over its quality.
                                                  Ron
                                                  #381055
                                                    I wouldn't replace it until it actually fails.
                                                    A squirt of switch cleaner is unlikely to void your warranty but replacing the pot might. Plus it's quite likely the dirt that caused the problem is now dealt with.
                                                    Ron Laden
                                                      @ronladen17547
                                                      Hi Neil, you are right I dont plan on changing it unless it actually plays up again.
                                                      Ron
                                                      p.s. with a bit of luck it may now go on for years with no problems.
                                                      Edited By Ron Laden on 17/11/2018 16:27:32
