Milling Southampton area?
Home › Forums › Help and Assistance! (Offered or Wanted) › Milling Southampton area?
  • #34011
    Chris Stevens 2
      @chrisstevens2
      #597461
      Chris Stevens 2
        @chrisstevens2
        I wonder if there is anyone close to Southampton, who might be able to help with milling SOHC Honda cylinder heads, to accept camshafts fitted with a bearing, rather than running directly in the head? Have a few I need doing, and could be more in future. TIA to anyone who responds to this.
        #597478
        Chris Evans 6
          @chrisevans6
          I can't help being up in the midlands but are we looking at car or motorcycle application ?
          #597482
          Chris Stevens 2
            @chrisstevens2
            Single cylinder Honda motorcycle engines, Chris. Wear is very common on these heads, but as most check them without releasing tension on the cam chain, the play/wear doesn't get detected that often.
            #597541
            John ATTLEE
              @johnattlee20632
              I am between Petersfield and Portsmouth. I have a Victoria U2 milling machine.
              Why not make some tooling (which might need a milling machine) and line bore using a lathe with the line boring tool running between centres and the tooling replacing the compound slide? That should keep the set up time down.
              Happy to chat on 'phone.
