Hi John and Mike!
Thanks for Your replies!
I have bought a unit blind (very reasonable price!), it is described as a Memlo transformer unit 41LV, primary volts 400/440v, secondary volts 12.5 to 25v, max. load 100 watts, 50hz.
John, I am using LED Battens for the main lighting in the workshop,the lamp will be for close in lighting and I wanted a traditional lamp for this.
I bought two Memlites secondhand last year, one has the built in rocker switch and wired with a standard 3pin plug so 240v, the other had no switch, the Memlo is for this one.
I will post some pics when it arrives.
Again, many thanks!
Cheers, Pete
