Maxitrak Showmans Engine generator
Home › Forums › General Questions › Maxitrak Showmans Engine generator
  • #23403
    Rod Ashton
      @rodashton53132
      Generator info
      #157625
      Rod Ashton
        @rodashton53132
        Could anyone help please with the spec. of the standard generator supplied on the Maxitrak Showmans Engine. Also the type of canopy lighting that might be run from it? Diode type bulbs? Wiring size? etc.
        #157633
          This is a 2" GMT so a small engine to start with which won't be a lot bigger than your showmans.
          It uses an outrunner motor as used in RC planes as an alternator and thats enough to power the 56 LEDs at 250rpm.
          #157679
          Rod Ashton
            @rodashton53132
            Jason
            Just what I want to do. Thanks.
            Could you give me the source of the coloured LED`s please. Also wiring size if you would.
            Rod
            #157680
              Not my engine. Join Traction Talk forum – just an e-mail needed and then the details are in this thread.
              The LEDs were clear but painted with Tamiya clear acrylic, the tinted one they do for model car indicators, brake lights etc
              Edited By JasonB on 12/07/2014 08:19:27
