Materials Sources
Materials Sources
Home › Forums › General Questions › Materials Sources
  • #62524
    KWIL
      @kwil
      Can anyone suggest a source of 5/32″ or 4mm SQUARE,  304 stainless steel?
      None of my usual suspects appear to have such a size.
      #21781
      KWIL
        @kwil
        Wanted
        #62526
        David Clark 13
          @davidclark13
          Hi There
          304 is usually available as sheet.
          regards  David
          #62527
          KWIL
            @kwil
            Folkestone Engineering  supply square bar in 303/304 but not these sizes. Must be sq. bar as I need to turn it as well.
            #62530
            Keith Long
              @keithlong89920
              Good luck Kwil I needed 6mm sq. bar in 303/304 this time last year, couldn’t find any wound up milling it out of suitably small round bar instead. Actually worked out reasonable price and not too tedious a job.
              Keith
              #62531
              Sandy Morton
                @sandymorton10620
                Metal Supermarkets seem to be able to supply most metal but they ain’t cheap!  http://www.metalsupermarkets.com/
                #62532
                  J&L do 4mm keysteel in stainless, here
                  Keith if you need 6mm again them Mallard do it
                  J
                  Edited By JasonB on 15/01/2011 20:17:52
                  #62533
                  David Clark 13
                    @davidclark13
                    Hi There
                    The request was for 304.
                    303 and 316 should not be a problem, it is the 304 that might be.
                    regards david
                    #62534
                    KWIL
                      @kwil
                      It would be useful to find 4mm in 303 as well.  Metalsupermarkets.com  start at 10mm square!! For J&L’s prices I would want 3Metres at that total price.
                      #62536
                        Shame you didn’t ask yesterday I went passed the door of my local stainless stockholder today, could have picked some up if they had it and given it to you at Ally pally. If you want their number pm me as I may be able to get over in the week.
                        J
