Unfortunately I don't have any old cars, or bits of cars lying around or I would be looking at using the bits (it's hardly surprising as I don't drive!). Even if I could buy a second hand stub axle I doubt I could get it home on public transport! It's a nice idea, I wish I had a big yard full of old machinery!
So far I have figured out I need 2 shafts, one 20mm diameter and one 35mm or maybe 40mm. Would EN1a mild steel be OK for both shafts? The 20mm shaft I will need to machine, the other one possibly just drill some holes in it.
Two pillow block bearings for the 20mm shaft. One pillow block bearing for the 35mm shaft and a 4 bolt flange bearing for where the shaft will go through the table.
Will the pillow block bearing hold the shafts vertically by themsleves, obviously the shafts will rotate with the bearings so do I need an attachment to stop them sliding out?
Also, I still don't know how to attach the shaft to the grinding table and wooden pulley. I appear to need flanges to do this, but should I try to machine these, or buy them?
I forgot the most important question, before I buy anything. Maybe this is obvious! I am assuming that a 20mm shaft will fit a pillow block bearing of 20mm internal diameter, is this correct? Or do people buy the shafts slightly smaller or the bearings slightly bigger, or machine the shafts to fit? It is probably a silly question!
David
Edited By David Brown 9 on 23/11/2015 19:56:53
