Manix lathe
Manix lathe
Home › Forums › Manual machine tools › Manix lathe
  • #94189
    David Clark 13
      @davidclark13
      Hi There
      Does anyone have a Manix lathe?
      If so, can they email [email protected]
      It is important, very important.
      regards David
      #11957
      David Clark 13
        @davidclark13
        Manix lathe
        #94271
        Sub Mandrel
          @submandrel
          I don't know if it helps, david, but Tony lists several 'badge engineered' versions at **LINK** which might make it easier to find an owner.
          David Clark 13
            @davidclark13
            Hi Stub Mandrel
            That makes it worse.
            But easier to explain.
            A reader contacted me to say his Manix lathe was wired up with the earth lead not connected.
            I was trying to find out if there were any more bad ones before printing a warning in the magazines. A one off is bad but many is a nightmare.
            regards David
            Edited By David Clark 1 on 12/07/2012 21:22:57
            #94275
            Sub Mandrel
              @submandrel
              >Ouch<
              If I'm paranoid about one thing, it's making sure my kit is earthed properly.
                I would say that the wide range of Badge-Engineered versions makes it essential that you put something in the magazines, David.
                On a happier note; Neil's link reminded me about the exquisite little Toyo ML1
                … always fancied one of those!
                P.S.
                Here is a little information about Manix.
                and here the company website
                Edited By Michael Gilligan on 12/07/2012 23:25:17
                Edited By Michael Gilligan on 12/07/2012 23:33:50
                #94293
                John Stevenson 1
                  @johnstevenson1
                  Posted by David Clark 1 on 11/07/2012 16:08:35:
                  Hi There
                  regards David
                  Is that the one without the tail [stock ] ?
                  John S.
                  #94300
                  Ady1
                    @ady1
                    These things are 50 years old now
                    If there's a risk then a buyer must accept it
                    Otherwise. Buy new
                    Edit
                    I shall refrain from swearing or quoting Darwinism etc etc
                    Edit2
                    How did you people ever manage to run most of the planet at one time????
                    Edited By Ady1 on 13/07/2012 00:24:05
                    #94307
                      Posted by Ady1 on 13/07/2012 00:20:21:
                      What things are 50 years old now ?
                      … Did you follow my links ?
                      MichaelG
                      Edited By Michael Gilligan on 13/07/2012 04:31:38
                      #94309
                      Springbok
                        @springbok
                        Is this a new machine as by EU Law it has to be a sealed plug. The web site of this company is not of use as it stated pictures not available. That alone for me would raise alarm bells.
                        David if this infact is a new machine I will support you on this issue.
                        Bob
                        #94310
                        John Shepherd
                          @johnshepherd38883
                          David
                          One off or not I think it is worth a mention along with a reminder/advice to check electrical connections on all machines in the workshop from time to time.
                          #94312
                            Posted by Springbok on 13/07/2012 06:54:22:
                            Bob
                            Bob,
                            I think you will find that it's only the "thumbnails" on the index page that are not available
                            … the links work, and there are datasheets.
                              P.S.
                              There appears to be a new web-site under develoment.
                              David … to avoid the speculation … do you know to which Model the original comment relates ?
                              David Clark 13
                                @davidclark13
                                Hi There
                                It was an opriginal Manix.
                                However, I don't know if it was a one off.
                                Hence the attempt to find out.
                                regards David
                                #94339
                                David Clark 13
                                  @davidclark13
                                  Hi There
                                  An old machine but purchased new and not been played with.
                                  regards David
                                  #94340
                                  Andyf
                                    @andyf
                                    On a similar theme, I know of a mini-lathe from the "Real Bull" factory which arrived with its fuse in the neutral line, so it wouldn't blow if there were a short from live to the metalwork of the machine. I don't know if this was a one-off.
                                    Of course, with the fused mains plugs we use in the UK, there is a second line of defence.
                                    Andy
