> Not troed silver soldering. What draws the solder into the joint? the heat or the flux?
> Neither, it's capillary action.
Well yes, but…
heat has to be sufficient to make the solder fluid enough and flux removes oxide/prevents it from forming and allows the solder to 'wet' the parent metal so both are required to create the conditions where the solder can be drawn into the joint by capillary action.
Actually… solder will flash across a hot, fluxed single surface so I suppose that surface tension alone rather than capillary action (surface tension action between closely spaced surfaces) is sufficient to draw solder across a surface.
