There is a view that a stud with a solid middle section is both heavier and weaker than one made from studding. Heavier obviously, and weaker in regard to fatigue failure as the studding is, in effect, one long stress raiser, and the load is not concentrated anywhere. With a 'proper' stud the bits of thread inside the female threads really are stress raisers. But it all depends on the purpose of the stud, of course. Many model studs do not have to cope with vibration.
Another thought – BA threads are not in any sense the 'right' thing to use as a scale version of a full sized part. So, if what you need is an approximation to a scaled thread, the range of metric threads currently around would be no less 'wrong' and quite a lot cheaper and easier to find, and to find taps and dies for, nuts, etc.
BA threads are certainly regarded as 'traditional' for model making, but as I say they do not match the 'to scale' need, and the only reason for using them for models in the good old days, I suggest, was the lack of any off-the-shelf alternatives.
Discuss …
Cheers, Tim
