machining 2 BA thread
Home Forums Help and Assistance! (Offered or Wanted) machining 2 BA thread
Viewing 25 posts - 1 through 25 (of 26 total)
  • #228241
    phil burley
      @philburley12227
      I have 2 lathes one imperial one metric , I would like to screw cut a 2 BA thread . But the pitch doesn't seem to be either . What am I missing here ?
      phil burley
        @philburley12227
        #228243
        Nobby
          @nobby
          HI Phil
          Could yo use a die ?
          Nobby
          #228244
          Emgee
            @emgee
            2BA TPI is 31.35 and metric 0,81mm pitch.
            Emgee
            Edited By Emgee on 04/03/2016 13:19:26
            #228246
            Lambton
              @lambton
              Phil,
              Do as Nobby suggests.
              If you use a good quality tail stock die holder you will be OK. There is no point in trying to screw cut any BA threads by "normal" methods. the posh way to cut them is to used a Coventry die head.
              Eric
              #228256
                Posted by phil burley on 04/03/2016 13:11:41:
                Some fairly specialised change wheelsdevil
                On your lathe of choice … screwcut part-depth, at either 32tpi or 0.8mm pitch
                This will give a track for the die to follow … finish with the die.
                Obviously, the acceptable 'part-depth' will vary according to the pitch error and the length of thread.
                #228257
                Roderick Jenkins
                  @roderickjenkins93242
                  If either of your lathes has changewheels as opposed to a Norton type gear box then you can very likely find a combination of changewheels to give a good enough thread using the program at **LINK** If you have a Myford with a gearbox then replacing the 24 tooth tumbler stud gear with a 20T gear and selecting 26tpi on the gearbox will give you a metric pitch of .814.
                  HTH,
                  Rod
                  #228259
                    On an imperial lathe 63:57 is a starting point that should allow you to add a further gear pair and get 2BA.
                    For Metric, fit them the other way round 57 driving 63.
                    AndyP
                      @andyp13730
                      Just to be perverse I put 0.81mm pitch into the little programs I use to work out gear trains for screwcutting on my C1 lathe and a different program for my metric Boxford AUD. In both cases I came up with a gear combination to cut that pitch either exactly for the C1 or with an error of 0.006% for the Boxford so it is possible at least.
                      I would use a die though.
                      Andy
                      #228295
                        Andy,
                        Just out of interest … what is the train for the C1
                        Thanks
                        Ajohnw
                          @ajohnw51620
                          My understanding is that BA is a metric specification. Try converting the diameters. 2BA for instance is 4.7mm dia.
                          A quote from the wiki
                          The pitch of 0BA is 1 mm and the pitch of each higher numbered thread is obtained by multiplying the pitch of the lower number by 0.9 so K-BA has a pitch of scriptstyle p=0.9^K.[1]:12 The major diameter is given by scriptstyle 6p^{1.2}[1]:12 and the hex head size (across the flats) is 1.75 times the major diameter.
                          All derived no doubt when there wasn't precisely 25.4mm to the inch. It's essentially an instrumentation type thread. It's closer to metric coarse than fine
                          angry 2 Lotus used 0BA to fix the radius arms to the rear hubs on the Europa. That cause me a lot of grief as other threads will fit and then work loose.
                          Bazyle
                            @bazyle
                            Goodness you people are slow today. You have a metric lathe and M5 pitch is 0.8mm. Don't try to tell me you are bothered by the .01 pitch error.
                            #228308
                              Posted by Bazyle on 04/03/2016 17:36:16:
                              That, Bazyle, would rather depend on the length of the thread.
                              … As yet unspecified
                              Bazyle
                                @bazyle
                                But it's patently not a leadscrew, just a fixing, so the engaged length is not going to be very long. Also it is possibly part of a Stuart Beam engine?
                                Edited By Bazyle on 04/03/2016 18:04:07
                                #228312
                                  Posted by Bazyle on 04/03/2016 18:01:18:
                                  Are you clairvoyant, Bazyle?
                                  #228313
                                  AndyP
                                    @andyp13730
                                    Michael
                                    I always have difficulty understanding other peoples change wheel descriptions so this may be wordy but hopefully clear.
                                    36 (fixed) on the spindle driving a 54 idler driving a 40 which shares it's stud with a 24 which drives a 40 on the 1.5mm pitch leadscrew.
                                    Andy
                                    #228318
                                      Thanks, Andy
                                      Not much help on my little Jason lathe [which has 32 (fixed) and a 16tpi leadscrew] but appreciated anyway.
                                      Ajohnw
                                        @ajohnw51620
                                        Personally if i didn't have a 2BA die I would replace it with M4.5 coarse. Really these days when people are buying things like taps and dies it's probably best to go for near metric sizes and forget BA. Arc for instance sell a set of the smaller sizes that starts at M1 that will cover the small BA sizes. A few more will cover BA's range.
                                        The only problem with older designs is that some 40 tpi and 32 tpi may be a good idea but metric fine may substitute for these in some cases.
                                        To me BA sizes don't need to be screw cut unless some one just wants to do it for fun. I wouldn't bother. Save it for bigger diameters.
                                          I'd hazard a guess that its for th piston rod on the Stuart beam which you do want a true as possible and being stainless a bit harder to cut with a die and not have it slip in the chuck putting marks all down your piston rod. Though skimming the piston to finished dia once its on teh rod is the best bet to get things concentric
                                          As suggested screw cut it 80% at 0.8mm pitch and finish with a die if you are not happy that your die will do it straight off
                                          John where are you buying M4.5 taps and dies, I've never seen them
                                          #228328
                                          Ajohnw
                                            @ajohnw51620
                                            Just as an example Jason
                                            It's part of the extended series. Not sure when the size steps exceed 0.5mm.
                                            LOL Forgot to mention I haven't bought any of these as I have a decent range of BA. However I did know that this size is about.
                                            Edited By Ajohnw on 04/03/2016 18:53:25
                                            #228334
                                            phil burley
                                              @philburley12227
                                              thanks everyone, its in stainless steel and my die is well worn , I wasn't allowing for a bit of an error , just comparing the exact pitches that I could produce , please excuse my beginners ignorance .Yes it is part of a ST beam engine
                                              regards Phil
                                              #228338
                                              Anonymous
                                                If you can't easily cut a 2BA thread change to 3/16" by 32 or 40 tpi. Taps are readily available and so are threading inserts that will give the proper Whitworth thread form.
                                                #228347
                                                Ajohnw
                                                  @ajohnw51620
                                                  Michael came up with the best suggestion really if there is a die about. You could probably screw cut to 90% plus depth and the die will still correct it.
                                                  Tim Stevens
                                                    @timstevens64731
                                                    Have you neglected the option of using 2BA studding?
                                                    Or changing the thread to 3/16 BSF which is so near you would never notice?
                                                    Tim
                                                    #228594
                                                      @mike89748
                                                      Tim, you beat me to it. I'd have substituted 3/16BSF – in fact, I'd been thinking about it since this thread started.
