Posted by Neil Wyatt on 12/10/2016 21:44:22:
2 Claiming the DIN standard as setting the drill size is a bit tenuous, and only makes sense when the tolerance range is given along with the matching thread engagement (a sensible 67% up to silly)
Sense at last
All that is needed now is a get on with it and if problems do occur realise why they can happen.
The whole area is a complete and utter nonsense when different sized bolts and screw can be fitted in the same tapped hole.
The make of the tap or drill doesn't matter. It's not a good idea to assume it does especially these days. eg Eclipse high speed steel. Dormer drills – not for me any more. Taps have various grades
Nuts, bolts and screws and dies too.
Personally I will stick with minimising the cutting pressure to avoid back cutting and to get the correct pitch on all threads. Really the best way to do that is for me to measure my own taps and do some sums. It's no use saying this is an 8mm tap because in practice it wont be 8mm dia. It's much the same with reamers which is rather annoying.
To me anyway.
I understand that the ISO tolerances are looser than what imperial tended to use and tolerances between parts have been shifted.
Anyway the OP has tapped his holes now and hopefully is happy with the results. He did get on with it and as expected in the majority of cases it will be ok and doesn't matter all that much. Small sizes and tough materials can be a bit more difficult.
I bought some serial taps recently. I was glad to see that some of the smaller sizes were very close to size. Probably by accident. Some one also mentioned one way of getting a decent fit was to skip the 3rd tap. Be interesting to see if that is correct.
Edited By Ajohnw on 12/10/2016 23:21:27
