M E Threaded Hex Bolts
Home › Forums › Beginners questions › M E Threaded Hex Bolts
  • #50534
    Speedy Builder5
      @speedybuilder5
      I am looking for a supplier of 1/8 inch x 40 tpi hex steel bolts (M.E) – Any ideas please.
      #5026
      Speedy Builder5
        @speedybuilder5
        #50537
        Sub Mandrel
          @submandrel
          Might not be the answer you want, but can you not use 5BA, which is 0.126″ diameter?
          I use them for 1 1/2″ screws at 1/12 scale.
          Edited By Stub Mandrel on 08/04/2010 21:58:22
          #50538
          thomas oliver 2
            @thomasoliver2
            I have checked all the usual suppliers and they all appear to stock only BA hex.headed screws. Personally, I have never seen ME screws advertised.   A 5BA screw has 3/16in across the flats hexagon head. This is obtainable in steel and brass of course,  so you may have to resort to making your own, or as suggested, use 5BA screws.  T.O
            #50540
            Ian S C
              @iansc
              1/8″ x 40tpi is also standard whitworth standard, have you thought of 3mm ? Ian S C
              #50546
              Circlip
                @circlip
                If GLR still supply Hex rod, you COULD roll your own.
                  Regards  Ian
