Little experience so advise needed
Home › Forums › Materials › Little experience so advise needed
Viewing 15 posts - 1 through 15 (of 15 total)
  • #421431
    Chris TickTock
      @christicktock
      hi Guys let me first say I have both a Sherline Mill and Lathe. My hobby ney obsession is old clocks. I wish to learn how to machine parts for platform escapements namely the balance staff which is approx 20mm long and are some type of steel, no doubt then hardened. This is micro machining. my initial questions relate to the fact that it is inevitable I will cock up a good few attempts so what material should I use to practice on for starters? I have taken advise on cutters and setup but any other advise including suppliers of Micro-100 carbide bits appreciated.
      regards
      Chris
      #29942
      Chris TickTock
        @christicktock
        Materials for experience
        #421439
          Welcome, Chris
          Don't waste your energy experimenting with other steels … Buy some 'Blue Pivot Steel' from one of the reputable supply houses: It is properly heat treated; which, of course, what imparts that lovely blue colour.
          … and beware : Some ebay Sellers are listing 'Steel suitable for making blue pivot steel' [or some such nonsense]
          MichaelG
          P.S. where are you located ?
          #421465
            The right equipment for the job is a Super Adept lathe
            #421479
            Chris Evans 6
              @chrisevans6
              Chris, where in the world are you based ? for practise turning you won't go far wrong with EN1A. Then buy your "Blue Pivot Steel" if you are close to Lichfield I can give you some bits to play around with.
              Chris.
              #421490
                Posted by Chris Evans 6 on 29/07/2019 16:38:56:
                … for practise turning you won't go far wrong with EN1A …
                Well that's me told
                Chris TickTock
                  @christicktock
                  Posted by Michael Gilligan on 29/07/2019 13:18:26:
                  Welcome, Chris
                  MichaelG
                  Hi Michael I live on the Cambridge area. thanks for the post guys.
                  Chris
                  #421543
                  duncan webster 1
                    @duncanwebster1
                    Chris.
                    If you're buying it in and you have the choice, EN1APb is even better to machine. The modern ref is 230M07 PB.
                    The lead stops it sticking to the top of the tool and developing the dreaded built up edge
                    #421555
                      Chris Evans, and Duncan Webster
                      Perhaps I was mistaken, but I thought Chris Judd wanted to practice turning things like balance staffs [see his opening post].
                      I know no-one who could make a useful 20mm long balance staff from EN1A [with or without added lead], so what is the point of him wasting his efforts practicing on that ?
                      The cutting characteristics of Blue Pivot Steel are surely what he needs become familiar with.
                        Posted by Christopher judd on 29/07/2019 21:28:45:
                        I have sent you a PM [personal message] Chris
                        Please check your Inbox [icon on the top green bar of this page]
                        duncan webster 1
                          @duncanwebster1
                          Posted by Michael Gilligan on 29/07/2019 22:52:46:
                          I read it that the OP wanted something easy to start with before attempting pivot steel
                          #421580
                          Roger Hart
                            @rogerhart88496
                            As said blue pivot steel is the stuff to use. The problem is that you can't easily harden the staff after making – you burn the pivots. So it has to be made from a good grade of steel hardened to spring temper from the get go.
                            A read of some of Donald de Carle's books might be an idea. The Web has a pdf. Also getting a pair of pivot files left and right (and they are not cheap if new). To check the size I have made a temporary staff from brass, easy and quick.
                            Usually hand turning with a lozenge graver is the traditional way but I could never get on with that tool and used engraving tools. Experiment, you will surely end up making a few before you settle on a technique that works for you.
                            You 'can' polish the pivots in the lathe but it is a bit risky. Some sort of support like a Jacot tool makes it less likely to bust the pivot at the last moment (v annoying).
                            You can also make a simple turns and do the job between centres. Make a little pulley, some cotton thread and a motor and you are good to go.
                            Enjoy.
                            #421590
                            Ron Laden
                              @ronladen17547
                              Good here isnt it, I had never heard of Blue Pivot Steel, learn something everyday.
                              Ron
                              #421608
                              IanT
                                @iant
                                You don't have to build clocks & watches to use watch-makers materials and tools Ron, they are very useful to model makers too. Don Gordon (a builder of small scale boats) wrote a very good series in ME in the 80's called "Low cost, High Precision" – well worth a read for any small scale modeler. Don used pivot steel to make very small diameter drills when required for instance.
                                You can get it in various sizes from Cousins UK. I purchased packs of assorted sizes from them some years ago and it can be a useful source of hard, small diameter steel.
                                IanT
                                #421611
                                not done it yet
                                  @notdoneityet
                                  Ron,
                                  Not sure if it is mentioned above, but the blue simply refers to the colour to which the material was historically tempered, after hardening. These days, they simply use temperature, rather than the colour, for controlling the tempering process, as it is(or should be) far more precise.
                                Home › Forums › Materials › Topics
