Lister Drawings
Lister Drawings
Home Forums General Questions Lister Drawings
Viewing 5 posts - 76 through 80 (of 80 total)
  • #127777
    Ennech
      @ennech
      The pump ptston to bore clearnce has to be less than the proverbial gnat's.
      I could be back leakage.
        Yes you probably need to lap the piston to the bore down to 1000 grit and also make sure the non return balls are seating.
        #127783
          Yes its got a decompression valve.
          J
          #127811
          HobbyNut
            @hobbynut
            Well the motor fired a few times today, with me spraying a tad of starter fluid into the intake tube, while cranking it with an electric drill.
            The pump and injector need rebuilding. I think I will use steel for them this time, and the injector will be to Meeks' sketch, or similar.The pump clearances are what I would consider tight, but not nuclear precision! I am also going to rethink the pump design somewhat. I will let you all know how that goes.
            I must thank you all for your help on this project, and I received a packet in the mail from a poster on here. I will document my work on that part. Thanks again.
            #127946
            HobbyNut
              @hobbynut
              I may try that after I build a pump that works!
