Lion tender springs
Lion tender springs
Home › Forums › Locomotives › Lion tender springs
  • #1268
    michael chalmers
      @michaelchalmers19148
      #148592
      michael chalmers
        looking for a starting point for spring length and wire diameter for Lion tender compression spring.
        Thanks
        #148600
        Ady1
          @ady1
          No 2792 for the 5in gauge titfield thunderbolt
          "The springs can be wound up from 18-gauge tinned steel wire"
          There are 10 turns on the 1/8 pin in the drawing
          #148603
          Ady1
            @ady1
            No 2789 for the 3 1/2"
            "Each box can then be
            fitted to the horns, and marked, so that
            it can be replaced correctly at any future
            time. The springs are wound up from
            20-gauge tinned steel wire, a job I
            have described many times; they should
            just start to compress when the box is
            at the bottom of the hornslot. Final
            adjustment can be made under load.
            – (Continued on page 544).
            Edited By Ady1 on 01/04/2014 10:56:27
            #148636
            michael chalmers
              Ady1
              Many thanks for the info, have found a length of spring which i can cut.
            Home › Forums › Locomotives › Topics
