LED “Fluorescent” tubes…
Home Forums General Questions LED “Fluorescent” tubes…
Viewing 15 posts - 76 through 90 (of 90 total)
  • #268807
    MW
      @mw27036
      Posted by Neil Wyatt on 28/11/2016 15:22:52:
      Posted by duncan webster on 27/11/2016 17:26:01:
      On another tack, I just bought some electrical equipment from a UK supplier. It is CE marked, but has a 3 pin plug which doesn't have a fuse built in. Is this allowed?
      No, the problem is that some countries use similar unfused plugs on low-amperage spurs rather than the UK's heavy duty ring mains.
      If you buy one direct from from Honk Kong you are the importer and could get nicked fro bringing in dangerous goods!
      Interesting stuff, i bought a rotary tumbler from Taiwan that came with what i suspected was an unfused plug, so i cut the b******d off and replaced it with a proper UK one. The body of the plug was waaay too thin for it to possibly contain a proper cartridge fuse.
      Michael W
      Tractor man
        @tractorman
        Just bought a 5 foot led batten light from screwfix so will be putting it up tomorrow and see how it compares to a traditional one.
        Hoping it will be a nice clean light. Mick
        #268815
        Russell Eberhardt
          @russelleberhardt48058
          Legally it is the importer of the product who is responsible for ensuring compliance with the CE marking directive not the foreign manufacturer. The British plug is made to a BSI standard and is not covered by any European standard so is not covered by the CE marking. That is unless things have changed since I was involved in the standards writing process.
          As far as buying directly from a non EU country is concerned, yes you are responsible but the genuine CE mark is only required if you "place the product on the market" that is if you intend to sell it commercially.
          Russell.
          #268822
            Posted by Bob Brown 1 on 27/11/2016 18:11:26:
            If Led bulbs reduce the load on a lighting circuit should we reduce the size of the fuse/breaker? I think our total house lighting load (all led) is less than 1.5amps with a 6 amp RCBO circuit breaker in consumer unit.
            Not if you want to use the arc welder featured in recemntly linked issue of Practical Mechanics "Plugs into a light socket"!
            Bob Brown 1
              @bobbrown1
              Posted by Neil Wyatt on 28/11/2016 17:17:42:
              What are going to weld using a light socket aluminium foil
              #268937
              Ian S C
                @iansc
                In years gone by people ran all sorts of the lighting circuit, radios, 1Kw heaters(that was about as big as they went), then someone decided that another circuit was require with plugs in the wall, and bigger fuses, first two pin, then three pin plugs, but from the begining in NZ the outlets were 10 amp, and they still are, no fuse in the plug. I think it's similar in Australia, although they use a different size of plug for 15 amp.
                My main reason for the change from compact fluro to LED is instant full light, no warm up time, and extended life.
                I have a copy of "Practical Wireles Servive Manual" by F. J. Camm, first published in 1938, republished in 1960, there is an interestingpicture in the section "Equipping a Service Workshop.  There is one three pin plug on the wall above the service bench for the electric soldering iron, battery charger, radio, lighting all run off the light socket.  I'v just read on a bit into the chapter, and find that the three pin plug is wired directly into the lighting circuit.
                Ian S C
                Edited By Ian S C on 29/11/2016 11:06:43
                #268944
                John Durrant
                  @johndurrant47282
                  Just changed the 5ft flou fittings in my garage/workshop to LED, used the 'Auralum natural white 144LED T8's'.
                  Purchased on Ebay. A bit expensive at £33 a pair but there is no rewiring of the units to do as they come with an adaptor that replaces the starter. So the tube is a straight swap.
                  The change was amazing, instant bright light, no buzz, no flickering. Turned my workshop from a Man Cave to Santas workshop.
                  #269071
                  Adrian Giles
                    @adriangiles39248
                    Due to total lack of headroom in my shed, conventional lighting was out. Bought one of the 3metre led self-adhesive strips, and stuck it up in a U shape along the ceiling cladding over the bench. Absolutely brilliant, gives virtually shadow free light over my lathe and mill, can see my c**k-ups so much better now!😂
                    #269093
                    Muzzer
                      @muzzer
                      I completely agree about the benefits of diffused / strip lighting over spot lights. Although the ubiquitous Ikea "Jansjo" LED lamp represents excellent value for money and is low voltage (safe for wet work), it generates a very concentrated light source. The resulting sharp shadows are counterproductive – although some surfaces are well lit, the remainder of the work actually becomes more difficult to see. To use them effectively, I reckon you also need good, diffused backlighting to eliminate the sharp shadows. So my primary lighting will be (LED) ceiling mounted battens, plenty of them.
                      I like the idea of the square panels but they work out quite a bit more expensive than the battens for the same light output.
                      #269100
                      Journeyman
                        @journeyman
                        With the LED tape you can posh it up a bit by using a purpose made extrusion and opaque cover, it looks neat and provides a heatsink for the LED's. A bit expensive but could be useful where headroom is limited. Also available in quadrant format to fit a corner. I think it is designed for under kitchen cabinet fixture.
                        Baldric
                          @baldric
                          Posted by Adrian Giles on 30/11/2016 02:50:32:
                          I did the same due to lack of headroom, 2 rows of 4m down the workshop (converted garage), I went for the ones with the most light output, but would have been fine with lower power units. Mine are fitted in the extrusion with the cover strip. The only problem I have had is one of the strips stopped working part way down, the solder joint between sections had cracked, a touch with the soldering iron fixed it.
                          Baldric.
                          #272250
                          Ian Hewson
                            @ianhewson99641
                            Hi
                            Ordered two 5 foot tubes from Ledkia, took 6days to arrive.
                            Fitted them by removing the chokes and starter as per instructions, they then would not stay lit, flicking on and off.
                            After replacing the chokes and using the led starter they worked.
                            The PDF on the web site stated the could be used without chokes or with them, but no paperwork came with the tubes, although a stuck on label on the tube shows them with chokes.
                            Apparently there are different classes of tube, some requiring chokes and some not, I seem to have got the type that needs a choke, so you need to check.
                            Ledkia did not respond to emails and whilst the say Ledkia UK they are a Spanish firm which was were the tubes were shipped from.
                            #272789
                            ianj
                              @ians
                              Having replaced the four 4 foot double florescent light fittings in my workshop with LED fittings I'm very impressed with the difference in brightness. BUT the down side of them is there's no heat from them, with the old fittings after a couple of hours in the work shop it got quite snug.So the electricity I'm saving on lighting goes on heating !!
                              #272797
                              Hacksaw
                                @hacksaw
                                Heads up! Screwfix clearance on now ! 5 pack GU10 5W or 3W Warm white …. £3.50 for a pack .
                                And they're still selling singles for same price .. does not compute
                                Led clear "normal " bulbs, with fake filament snazzy vintage smiley , 7Watt _ but light of a 60W £1.99
                                #272820
                                Muzzer
                                  @muzzer
                                  Posted by ian j on 19/12/2016 16:32:03:
                                  I'd be surprised. As noted earlier in this thread, fluorescents and LEDs have a similar power consumption for the same light output (measured in lumens). If you are suggesting that the LEDs are brighter, they are likely to be taking more power.
                                  It's possible your original fittings had a low power factor if they were old (0.5 may be typical) but you only pay for the real power which generates the heat anyway so I suspect the nameplate wattage is directly comparable with that of a modern high power factor fitting. Perhaps somebody could confirm. The real power all ends up as heat (and some light).
                                  Murray
