LBSC Cylinder Thread Size
Home › Forums › General Questions › LBSC Cylinder Thread Size
  • This topic has 3 replies, 3 voices, and was last updated 2 May 2022 at 01:27 by duncan webster 1.
  • #596627
    Bruce Voelkerding
      @brucevoelkerding91659
      both the LBSC designs for Maisie and Juliet show the Cylinder mounting hole size as No. 21. I assume the hole size No. 21 in England is the same as here in the USA, that is 0.159". In neither of these drawing sets do I see the actual Screw size for the attaching Screws. The 0.159" seems rather coarse for 4BA. Would LBSC have expected someone to use a 5/32" Screw (I'm assuming that back then someone would have a 5/32"-32 Die or some such thread) ?
      #28689
      Bruce Voelkerding
        #596630
        Nicholas Farr
          @nicholasfarr14254
          Hi Bruce, LBSC's notes says the cylinders are attached with 5/32" screws or bolts with the nuts inside the frame, for Juliet, I guess that Maisie would be the same.
          Regards Nick.
          #596649
          duncan webster 1
            @duncanwebster1
            5/32 * 32 is a standard bsw size, and I think was what Meccano screws were in the olden days. Your chance of finding new screws is slim, I'd use m4
